Show me your APS TT Boost Curves!! :D
Old Oct 4, 2007 | 10:25 PM
jining's Avatar
jining
Default Show me your APS TT Boost Curves!! :D
Well, after having my aps TT self install looked at by a shop and fixing an exhaust leak on the exhaust manifold, I figured it was time for a tune. I took it to a shop called Dyno Authority in Redmond,WA. Great guys, and very knowledgable. Unfortunately.. everything didnt go as well as planned. It seems that my boost curve is extremely odd, goes up to around 5psi, dips back down to 4 and then gradually goes up to reach peak boost. Looks like a supercharger boost graph. Did extensive tests for vaccum leaks including smoke and compressed air and also double checked that my hks evc was working. No dice.
We suspect its my aps 2.5" exhaust. I am only trying to run 8psi, and after installing this aps 2.5" from my invidia g200, I cannot reach max boost in 5th gear at 3k rpm like I could with my 2" g200. Only around 5psi max.
Very odd. Anyways, please show me your boost curves so I can get an idea of what it should look like.
Thank you in advance,
Aaron
Old Oct 4, 2007 | 10:34 PM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by jining
Well, after having my aps TT self install looked at by a shop and fixing an exhaust leak on the exhaust manifold, I figured it was time for a tune. I took it to a shop called Dyno Authority in Redmond,WA. Great guys, and very knowledgable. Unfortunately.. everything didnt go as well as planned. It seems that my boost curve is extremely odd, goes up to around 5psi, dips back down to 4 and then gradually goes up to reach peak boost. Looks like a supercharger boost graph. They spent 6 hours trying to tune it out, only charged me for 2. Did extensive tests for vaccum leaks including smoke and compressed air and also double checked that my hks evc was working. No dice.
Aaron
sounds like a Wastegate spring/actuator issue.We av ehad no problem making over 12 psi on the 2.5" exhaust.
Old Oct 4, 2007 | 11:27 PM
jining's Avatar
jining
The problem is not that we aren't able to reach high boost, the 2 problems are these:
-Boost graph is linear like a 45 degree angle (besides the strange boost dip), reaching max boost (10psi even though my goal is 8psi) @ around 6k-6.5k, instead of reaching max boost at 3k or so like it should be.
-Baseline boost reaches 10psi, even though my actuator springs are the APS 8Ib springs. I have even heard of these springs having a hard time holding 8Ib of boost and only showing 4-5psi baseline.
My goal is only 8psi with the stock block. What baseline boost are you getting with the 2.5" exhaust? I can see the wastegates creeping open at as little as 5psi on the dyno. Its almost like the wastegates open and close at 5psi resulting in the dip in the boost graph.
Do you think 2.5" is too little backpressure for the small amount of boost i'm aiming to run? I never had issues reaching max boost in 5th or even 6th gear with my 2" g200, and I never had overboost issues.
Old Oct 4, 2007 | 11:41 PM
Julian@MRC's Avatar
Julian@MRC
We need more info on your set up...post EVERYTHING and a dyno graph please.
Old Oct 4, 2007 | 11:47 PM
jining's Avatar
jining
**** I dont have a dyno graph printout, we were so dissapointed we didnt really even think of it.
When I configured the HKS EVC 6 and did a 4th gear pull on the dyno to determine the baseline boost, it does the same weird boost dip. Basically the boost builds like this 0-1-2-3-4-5-4-4-5-6-7-8.
Might help you out, im trying to think of all the info I can.
Thanks for your help.
My setup (stockblock):
Aps TT (tuner) swapped the 12psi actuators for 8psi actuators
Utec
HKS EVC 6
Deutschwerks 650cc Injectors
CJM Stage 2
APS 2.5" Exhaust
APS 2.5" Downpipes
Old Oct 5, 2007 | 12:16 AM
Julian@MRC's Avatar
Julian@MRC
Utec
HKS EVC 6
CJM Stage 2
APS 2.5" Exhaust
APS 2.5" Downpipes
Your problem is the actuator swap. Had you left your stock 12 psi actuators, the car would make about 7-8 psi on the base setting, you swappin in a lower actuator and are now asking the EVC to raise the base boost..The base boost on the pair of the 8 psi actuators might be in the 4-5 psi area. This is why your getting the drop then spike.Its setteling in on its base boost, then the EVC is raising the boost level. Thats why your chart may be linear..Try running BOTH vacume ports on the actuators directly to a pressure souce and see what kind of boost it builds.This will be your true baseline boost setting..Then set the EVC baseline for that psi and raise the boost within the EVC from there.
Old Oct 5, 2007 | 04:02 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
try to have your tuner unhook the pressure line completely from the actuators AND plug up the hole on them as well. plugging the hole on them will give you a little more boost because it makes the actuators airtight so it is fighting actual suction and springs to open the wastegate flap. this will give you the max boost you will be able to reach with your setup.
dont do this yourself, make sure you are on a dyno in the hands of a good tuner...
Old Oct 5, 2007 | 08:03 AM
jining's Avatar
jining
THe evc is not controlling the boost I believe because we were doing pulls in 4th gear during the EVC initial setup to get the baseline boost, and it would still peak at 9-10psi.
Even when we take the EVC out of the equation is doesnt seem to have any effect and peaks at 9-10PSI. Still with the weird dip around 4-5 psi.
The tuner did hook it up the actuators to a pressure source and we noticed the wastegates begin to open at around 5psi. No matter the baseline setting on the evc, be it 2 pounds baseline, 4 pounds, 6 pounds , 8 pounds or 9 pounds, it still is boosting to 10psi. :P
Is there no way it could be the exhaust? Has anyone run the 2.5" with 8Ib and had good results?
Old Oct 5, 2007 | 08:16 AM
jining's Avatar
jining
If either of you knowledgable gentlemen wouldnt mind calling my tuner up and talking to him, he could give you better answers then me
Dyno Authority: 425-869-8324 (Tuner = Tim) or you can talk to Ryan he was there as well.
Thank you
Old Oct 5, 2007 | 09:21 AM
jining's Avatar
jining
Thats the weird thing.. the base boost with my invidia 2" was 4.5 PSI in 4th gear, but with this APS, it sits at around 4-5 psi from 3k-5k and then after that it dips down 1 psi.... lingers..... then goes ALLLLL the way up to 9-10 linearly to 6.5k. The tuner had never tuned such a stubborn car before he told me lol.. 6 hours on the dyno :P
Old Oct 5, 2007 | 09:24 AM
jining's Avatar
jining
Just incase you were wondering @ the peak it put down 390/390 @ about 10psi on a Mustang. No detonation.. but I dont want to run that high boost.
Old Oct 5, 2007 | 09:41 AM
Zivman's Avatar
Zivman
You obviously have something installed or hooked up incorrectly. the exhaust is not the problem, especially if you are able to hit 10 psi at redline.
Recheck the EBC install. make sure everything is not only wired properly, but the settings are correct.
Did you make sure your preload on the wastegate actuators was set properly? I would suggest at least a 1/2 hole preload.
I would do what Jeremy suggested. Take the feed to the actuators and clamp it off. The car should just keep making boost at that point. Carefully watch your boost gauge and be sure to let off if it starts climbing out of range - preferrably let your tuner do this on a dyno. If you can't just make a steady increase in boost this way, you have mechanical issues.
Old Oct 5, 2007 | 11:04 AM
terps's Avatar
terps
I just got the APS single kit installed and had similar problem... ide hit 4psi around 3k and then creap up to 10, actually over boosting.I have a qtp cutout that switched from stock exhaust to 3.5 open dumps, haha. Dave at Function:Tuned fixed it, now it hits hard. It was crazy what he did, frankly still dont really understand it but he know his stuff. now making 370rwhp at 9psi( little less actually think defis read high) on Dyno dynamics.
Old Oct 5, 2007 | 12:29 PM
jining's Avatar
jining
We did take the feed off the actuators as you suggested, it still hit around 9psi and still had the strange boost curve. Im guessing it is most likely actuator preload as you said. How exactly should I have preloaded the actuators? Wish I had addressed this issue when my motor was out last week... damnit.
Old Oct 5, 2007 | 01:37 PM
Zivman's Avatar
Zivman
With the wastegate flapper shut and the actuator arm not conected, tighten down the actuator arm so you have to pull it approximately 1/2 of the hole (the opening) to fit it to the wastegate arm
Right click save as for video
Old Oct 5, 2007 | 02:05 PM
jining's Avatar
jining
Ah.. very useful video thank you. Well.. I definitely did not do that correctly Im taking it back to the shop thursday and we will attempt to get at them with the motor still in the car. LHS shouldnt be bad but the RHS one requires pulling out the alternator from what I remember. :P
Thanks a lot for your help guys.
Old Oct 7, 2007 | 08:53 PM
Weqster's Avatar
Weqster
sounds like wastegates arnt pre-loaded correctly
taking pressure source off the wastegates should yeild unlimited boost.
Old Oct 8, 2007 | 04:39 PM
jining's Avatar
jining
yea seems to be the general concensus and most reasonable solution. Ill keep you guys posted.
Any doubts on being able to access them with the motor still in the car? RHS will be the tricky one no doubt.
Thanks again.
Old Oct 15, 2007 | 12:21 AM
jining's Avatar
jining
well, we preloaded the actuators to 3/4 a hole and hooked them up to a compressor to crack open at the same time at 6.5 Ib, still has a strange dip on the boost graph.... we are out of ideas on that issue.. but it peaked at 410rwph and 400tq on a mustang dyno @ 8psi so im happy about that Got water injection on the way for some added safety !
Old Oct 15, 2007 | 03:58 AM
Quamen's Avatar
Quamen
Just a question but do you have the boost controller setup for the right wastegate type? There shoul be a setting on the back of the HKS for an internal wastegate setting (swing) and a external wastegate setting (poppet) which will affect how the controller controls boost. On my single turbo two years ago we had a similar problem and we hade the EVC on SV when it should have been on PV for my external wastegates.
