How much hp do high flow cats add to the vortech kit?
Old Oct 15, 2007 | 08:50 PM
Wicked350's Avatar
Wicked350
Default How much hp do high flow cats add to the vortech kit?
I tried searching but I was wondering if anyone has done before and after dyno tests with stock exhaust and then high flows...
Old Oct 15, 2007 | 09:58 PM
Mr_pharmD's Avatar
Mr_pharmD
Your best bet is to save up and get majority of the mods u want bc no one is crazy enough to buy 1 part at a time and waste their money on a tune for each upgrade. This isnt NA anymore where u can just buy 1 part at a time and expect not to go lean and BOOM .
Cats arent going to give u much pw if u dont change out your whole exhaust.
Old Oct 16, 2007 | 04:16 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we have a few times, really didnt make any difference with high flow cats and test pipes. same hp range, little more or less boost depending on which ones.
Old Oct 16, 2007 | 04:36 AM
dlt1cy's Avatar
dlt1cy
Are you saying there's not much difference tp vs hf or are you saying there's not much difference between stock cats vs tp/hf?
Old Oct 16, 2007 | 09:12 AM
Q45tech's Avatar
Q45tech
http://www.sccoa.com/articles/cwexhaust.php
Around 5 psi in front of main cats at redline is a good number. Each psi [measured after manifold before cat] of back pressure is roughly equal to 2 HP left on the table.
Very very very loud designs maybe ~~ 4-5 psi. OEM cat typically have a 2-3 psi backpressure and the exhaust system adds 2-3 psi
http://www.tomorrowstechnician.com/tt/tt020526.htm
AbrasiveRaysive
Sep 20, 2021 02:29 PM
