03 tt help needed
Old Nov 12, 2007 | 05:29 PM
auggiez33tt's Avatar
auggiez33tt
Default 03 tt help needed
Hey everyone I just bought an 03 base Z with a PE twin turbo kit. I was told the car has a base tune through an ss box and has very mild mods. The car is great but I have been having a few problems. First the a/c turns on and doesn't turn off when I romp on it. It pretty much turns off when it wants to and can get quite annoying. Second :The car has a strong smell of fuel when i fill up the tank and also during rough driving I have stillen test pipes installed. I was told by the seller that he had the dealership check it out and they could not find the prob but sait it nothing to worry about i saw the reciept. Third: where is the ss box usually located on a Z I cant find mine. I appreciate any advice provided thank you all.
Old Nov 13, 2007 | 03:39 PM
superchargedg's Avatar
superchargedg
Damn Noobs
1. Cant help you on the ac problem.
2.Sounds like the o ring at the fuel pump has gone bad or not installed correctly.
3.Test pipes will give you a strong smell of gas fumes.
4.Have no idea where they put the ss box.
Old Nov 13, 2007 | 05:01 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
The ac control box is behind the dash below the radio. To get to it, pull up the plastic piece around the shifter. The ac control is a white box. The ribbon cable may be loose which may cause the random WOT from the AC.
sherm
Apr 11, 2020 05:21 PM
