which turbo is the real deal here...
Old Nov 13, 2007 | 12:03 PM
jcrocka288's Avatar
jcrocka288
Default which turbo is the real deal here...
http://www.nissansportmag.com/shooto...oshootout.html
in that link while reading up on all the dyno readings greddys seems to be top of the line in torque as well as hp..my question is people don't really talk it up to much..just wondering, while im looking for the best answer to start my Z off with some serious power, which turbo does everyone think is the best setup and y does greddy not seem to get the same respect as others? is it a weak setup? thanx everyone
(also would just like you to keep in mind this is a daily driver) ...but still doesnt mean it cant be a beast)
Old Nov 13, 2007 | 12:05 PM
Blu_Blur's Avatar
Blu_Blur
Last time I checked, The GReddy system wasn't very complete as it utilised an EMS that wasn't up to the task, used stock injectors and removed the front reinforcement bar of the car.
Many people feel that if you go with Greddy, get the tuner kit if available so you can buy the individual parts that you really should've gotten in the first place.
Old Nov 13, 2007 | 01:46 PM
TENGAI's Avatar
TENGAI
GReddy kit comes with RC 440cc injectors, uses the eManage for tuning (which is sub-par for many on these boards in terms of reliability and control). They don't offer any kind of "tuner" kit. You get the base kit, and the intercooler kit. I don't know of anyone who's running the kit without the intercooler...
FWIW - I've heard from a ton of shops that the GReddy is second to none in terms of fitment and reliability. BUT - if you want a better EMS, you need to buy it, if you want a fuel return system, you need to buy it, etc. It's not a "complete" kit out of the box according to most, but it's definitely a good product...
Not sure what "negative" things you've heard, but most of the guys running strong built block setups here run the GReddy twins.
Old Nov 13, 2007 | 02:24 PM
Blu_Blur's Avatar
Blu_Blur
For the most part, if you have the money to go turbo, you also have the money to go with a better EMS. It's not that big of a deal and I personally would go with a Greddy system also.
Old Nov 13, 2007 | 02:47 PM
NETSHARK's Avatar
NETSHARK
Lets do it this way, GReddy Kit With Intercooler for $5500-$5800 and you need a EMS, Return Fuel System, and a BOV.
While APS is for $7,900 and you get everything you need but including a Crappy EMS (at least its better than the E-Manage maybe similar to it but its not as reliable as others on the market well at least its not good at higher than 380-400 WHP), second thing the Injectors they are rated at 500 cc at 4.0 Bar (58 psi) because APS use a 50 PSI of Base Fuel Pressure instead of 40 PSI like the others when rating the Injectors, so they are less than 500 cc don`t be fooled.
Ok APS Tuner Kit is for $7,000 and it doesn`t include the EMS and the Fuel system.
am not gonna comment about Turbonetics because Turbonetics is only good for no more than 450 WHP and its not recommended for the person who`s looking to upgrade in the future.
The Pros of APS:
Water Cooler Turbochargers,
Everything is supplied,
No Need to remove the front reinforcement bar.
Cons of APS:
The Crazy Price,
The EMS,
The Fuel System, its alright but still there`s a better ones when you compare it to CJM or AAM.
The Internal Wastegate has less control when compared to the External.
Pros of GReddy:
Bigger Turbos than APS so more power is expected.
Best Priced over them all,
External Wastegate vs the Internal on the APS.
Cons of GReddy:
Oil Cooled Only Turbochargers,
Crappy EMS,
You Have to remove the front reinforcement bar (some people did manage it by modding the front bar somewhere but its so possible)
Some items included are available in better quality such as the oil lines (Forged Performance carry the stronger ones).
if you wanna ask why GReddy didn`t include a BOV, think of it you can have whatever BOV you want not like APS you are limited to theirs.
so now lets think of it that way
GReddy TT/W Intercooler $5500
CJM Return Fuel system Stage 1 $985
Walpro 255lph Fuel Pump $99
BOV $180
EMS, its up to you but lets say u got the
GReddy E-Manage Ultimate:
GReddy eManage Ultimate Main Unit $499
GReddy eManage 3Bar pressure sensor $105
GReddy eManage Ultimate Supplemental Harness $42
or you got
UTEC:
Turbo XS-UTEC Engine Management System $800
Turbo XS MAP Sensor $99
GReddy with everything listed when chosing eManage is $7,410 and when chosing UTEC is $7,663 and APS Tuner alone is for $7,000.
P.S: if you ask which is better eManage Ultimate vs UTEC of course UTEC is the winner.
Old Nov 13, 2007 | 03:23 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Or you can do it the easy way and contact shariff at forgedperformance and get one of his greddy twin,s stages.There are quite a few stage,s that come with everything you will need.
Old Nov 13, 2007 | 05:58 PM
Alberto's Avatar
Alberto
Cranky FI Owner
GReddy is WEAKSAUCE I wouldnt recommend it...Stillen Stage 1 is where its at!
Old Nov 13, 2007 | 07:37 PM
r0mey's Avatar
r0mey
not like either of us have made power with it
Old Nov 13, 2007 | 07:50 PM
z350boy's Avatar
z350boy
If your car will be a dd then I suggest you consider the Jim Wolf TT kit. It will give you around 400-420 whp. You will get a conservative boost of 6-8 lbs boost. You will also get his split second management system ( some say it's ok but could be better). The car will handle like stock (until you step in it). The JWT TT kit is a reliable safe kit that allows for future ugrades. I think hat might be something to consider.
Old Nov 13, 2007 | 08:39 PM
Escobar's Avatar
Escobar
interesting read. Greddy has to be the best bet.
Old Nov 13, 2007 | 09:24 PM
unkn0wn ryder's Avatar
unkn0wn ryder
i run the greddy TT w/ a utec... no problems here.... lol on the other hand a friend of mine got the APS TT AND BLEW HIS MOTOR while getting tuned....
Old Nov 13, 2007 | 09:29 PM
Triple8Sol's Avatar
Triple8Sol
If I were to ever go TT (highly unlikely), Greddy is the only option imo. All the reasons were basically listed above in those highly detailed posts...
Old Nov 14, 2007 | 06:28 AM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
I beat my brains out asking myself the same question. So when I found this website I noticed the senior members would say "USE THE SEARCH FUCTION" when a new guy would ask a question such as this, so I did. I looked at countless threads of turbo installs, engine builds and dyno runs. I called just about every reputable vendor and asked questions. I also had someone take me for a ride in their turbo car. After all that I decide the Greddy kit and HKS v-pro were right for me. My car is @ SGP now and everything is being installed and tuned, It sould be ready hopefully before Thanksgiving, I will start my own thread and have some pics as well.
If I were you I'd call MRC or VTR, use the search function and check these out:
https://my350z.com/forum/questionable-posts/294038-turn-key-turbo-package-fall-winter-special.html
https://my350z.com/forum/showthread.php?t=278670
Good Luck.
Old Nov 14, 2007 | 06:40 AM
IIQuickSilverII's Avatar
IIQuickSilverII
specially you
Old Nov 14, 2007 | 07:38 AM
Blu_Blur's Avatar
Blu_Blur
Well, you don't NEED a fuel return system.
Old Nov 14, 2007 | 07:48 AM
Quamen's Avatar
Quamen
+1 because turbos blow (pun intended)
Old Nov 14, 2007 | 09:14 AM
jcrocka288's Avatar
jcrocka288
hey thanx everyone for the help looks to me like the greddy kit can hold its name pretty well just needs a little extra help with some different parts to make the kit show its true colors...thanx alot defiantly left me with a easier choice to make..now im just choosing between jwt or greddy..either with certain mods to add to each kit.
Old Nov 14, 2007 | 03:02 PM
superchargedg
Damn Noobs
Hey bert i still have the kit if you wanna try it out.......greddy,s pushing into a stillen ooooooooooh aaaaaaaaaaaaaaaah.
Old Nov 14, 2007 | 04:04 PM
XKR's Avatar
XKR
Totally agree. It drives like stock until the 500 + rwhp kicks in. Thank God that Sharif talked me out of the "Other" turbo kit that I wanted to have him install. Have someone give you a ride in a car with a JWT setup, and then compare it to the others.
Good luck
Old Nov 14, 2007 | 06:34 PM
DanielW's Avatar
DanielW
i think the general consensus is that greddy with a utec is the best bang for the buck out there but I would personally prefer the JWT kit
