Knock on 0 Column with Utec using Speed Density.
Old Nov 19, 2007 | 01:19 PM
athenG's Avatar
athenG
Default Knock on 0 Column with Utec using Speed Density.
Hey guys, I posted this here since most FI'ed cars uses Speed Density with Utec. Lately I have been getting some random knock on my 0 Column under ECU control (No Boost). This happen mainly on part throttle or just around before I hit 0psi boost. My A/F under no boost is the same the first time I got my car and never had this problem before. ECU doesnt seem to pull much timing when there is knock. I might clean my MAF in a few day and see if that help.
Here are some logs and any input is appreciated.
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SIG] [IDC%][IGN][VOEF][BMV] [WBO2]
483.03 2502  -3.8 3.1   35    0   0  29.3  11.8 ECU  100    000  12.50
483.13 2529  -2.2 3.1   35    0   0  26.3  20.0 ECU  100    000  13.19
483.23 2485  -1.6 3.1   37    0   0  23.2  13.5 ECU  100    000  13.12
483.32 2536  -1.4 3.2   40    0   0  22.4  15.1 ECU  100    000  13.72
483.43 2570  -1.1 3.2   41    0   0  21.4  15.6 ECU  100    000  13.55
483.53 2544  -0.7 3.2   41    0   0  21.2  14.6 ECU  100    000  13.63
483.63 2558  -0.7 3.1   40    0   0  20.2  14.8 ECU  100    000  13.66
483.73 2572  -0.6 3.2   41    0   0  22.3  15.2 ECU  100    000  13.70
483.77 2604  -0.5 3.2   41    0   1  20.3  14.3 ECU  100    000  13.58
483.83 2618  -0.5 3.3   42    0   1  19.3  16.4 ECU  100    000  13.57
880.36 4480  -8.9 2.8   16    0   0  39.0  11.3 ECU  100    000  15.32
880.46 4504  -8.9 2.8   16    0   0  39.0  11.5 ECU  100    000  14.61
880.56 4492  -8.9 2.9   22    0   0  39.2  11.9 ECU  100    000  14.57
880.66 4522  -7.6 3.2   22    0   0  37.1  15.6 ECU  100    000  13.74
880.76 4541  -6.3 3.4   23    0   0  32.9  17.5 ECU  100    000  13.47
880.86 4528  -6.1 3.3   23    0   0  35.1  18.0 ECU  100    000  13.08
880.96 4553  -6.2 3.3   23    0   0  35.0  18.8 ECU  100    000  12.95
881.06 4578  -6.1 3.3   21    0   0  28.0  17.8 ECU  100    000  13.02
881.16 4572  -6.0 3.4   20    0   1  33.9  17.4 ECU  100    000  13.39
Old Nov 19, 2007 | 06:15 PM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Code:
Post up your knock sensitivity as well as a chart of whats done to your car. That'd help alot What kind of fuel are you using as well? Also whats it like on the transition into boost, how's your a/f in the 10% column?
Old Nov 19, 2007 | 06:46 PM
Mike@Altered's Avatar
Mike@Altered
What year is your G and what size injectors do you have?
Old Nov 19, 2007 | 07:03 PM
athenG's Avatar
athenG
I always use 93 octane and also tuned for 93 octane. I have also used different Brand of Gas and have gone at least 4 tank of gas and still have problem. There is nothing done on the car except this thing start happening when the weather got colder. My A/F on my 10 Column is about 11.8-12.2 give and take so I don't think there is a big jump there. I was going to reduce the sensitivity on my Knock Threshold but never had this problem in the summer.
Old Nov 19, 2007 | 07:04 PM
athenG's Avatar
athenG
I have a 2005 G35 6MT (Revup) and have 440cc injector.
Old Nov 20, 2007 | 02:33 PM
Mike@Altered
It probably is knocking, which is a problem on the RevUp with boost when not setup properly. I would not recommend changing the knock parameters as they are lower (less sensitive) than we normally set them up already.
With 440cc injectors you have to take a good amount of fuel out of the MAF voltage which tends to increase the timing = mid throttle knocking. When we put together a similar setup we Flash the ECU to scale for the 440cc injectors and take out a few deg of factory timing in the pre-UTEC speed density zone.
Hope this helps,
Old Nov 20, 2007 | 03:09 PM
athenG's Avatar
athenG
Most of my knock happen in the 2000-3000 rpm (90% of the time) and my threshold there is set to 100 (max is 125). Are you saying that 100 is high for that rpm? I did some research and they suggest to set it up to 90 at 2000-3000rpm. I rarely get any knock higher than 3000.
Thanks for the input though!
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
CrowzRSA
Sep 21, 2015 04:00 PM
