I never see anything like this before....
Old Nov 29, 2007 | 05:39 AM
al_v's Avatar
al_v
Default I never see anything like this before....
A month ago I did a thread about my dead clutch , so I spend the money in a new one , and it take more than 3 weeks to get here.
Yesterday I was removing my clutch and my surprice begin , one flywheel bolt were broken in there , and the head of that bolt doesn´t release the disc clutch , so the problem never was in my clutch
My Fidanza flywheel is misaligned and the guide is broken.
Please take a look on this pics:
Old Nov 29, 2007 | 05:45 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
who installed the clutch the first time. that sucks. that could cause some serious unwanted main bearing wear as well. i would drain the oil and take off the oil pan before i started that car back up...
good luck
Old Nov 29, 2007 | 01:39 PM
al_v's Avatar
al_v
good luck
I did the job the first time , the bolts were tighten to 65 lb-ft.
Someone had a problem like this????
Old Nov 29, 2007 | 03:39 PM
westpak's Avatar
westpak
SFZCC
I have seen where a few broke off, did you install the flywheel with some lubricant on the bolt threads? the manual suggests oil, this helps the bolts thread all the way without resistance from the thread and get a good torque on them.
Old Nov 29, 2007 | 03:54 PM
al_v's Avatar
al_v
I can´t remember , but maybe did the install without any oil on it , I will do now.....thanks Gus.
Old Nov 29, 2007 | 03:58 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Ive used loctite on them plenty of times and been able to get them out if ive needed to. Never seen that before.
Old Nov 30, 2007 | 03:37 AM
ARLETOS 350Z's Avatar
ARLETOS 350Z
I you look to my older posts,in 04 i had almost the same problem,but to the oem flywheel-bolts and almost a run-out clutch at only 3500klm,as the car was pretty new!!!,but the dealer chaged all,and i mean clutch-pressure plate-bolts but didnt use locktite because the mother nissan of netherlads didnt find it good, without a second word..
Justin100
Jun 12, 2014 06:04 PM
Dsalvo
Aug 14, 2011 06:49 PM
Z_enthusiast
Dec 4, 2010 09:19 PM
