yet another vortech failure
Old Dec 7, 2007 | 06:17 AM
eez's Avatar
eez
Default yet another vortech failure
yet another vortech failure...my car is cursed.
problem #1 - Had it tuned yesterday and didn't have enough duty cycle from the 440 injectors to go past 5500 RPM.
problem #2 - Started the car this morning and I believe the barrings failed, since the SC let out a nasty screeching noise. Unhooked the SC belt and noise went away. I purchased the SC in august, so I assume I have the dreaded barring failure.
anyway it was producing some nice power and boost, before the injectors ran out. Here are the charts
Old Dec 7, 2007 | 06:19 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
hey man, sorry about your luck. get that thing back to Vortech so you can get it fixed and get it back on the dyno.
Old Dec 7, 2007 | 06:31 AM
sentry65's Avatar
sentry65
the burninator
the nasty screeching noise is likely your belt needing to be tightened. Is it by chance getting colder where you live? That could be the belt being a little looser after sitting all night in the cold
Old Dec 7, 2007 | 06:39 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
did you take the filter off and inspect the inner housing for rubbing/scratching?
Old Dec 7, 2007 | 06:46 AM
eez's Avatar
eez
not yet. I built a custom CAI, so I need to remove the bumper first.
eez's Avatar
eez
def not the belt. It's ear piercing. + I took off the SC cog belt and the noise went away. Actually it has gotten warmer.
Old Dec 7, 2007 | 07:09 AM
THE TECH's Avatar
THE TECH
I don't know how the 440s could be the problem. More likely a tuning issue or SS Box problem.
Old Dec 7, 2007 | 07:11 AM
eez's Avatar
eez
I have a UTEC and the tuner (Mark @ SGP) said he ran out of duty cycle.
Old Dec 7, 2007 | 07:15 AM
THE TECH's Avatar
THE TECH
Still doesn't makes sense as the 440s are large enough. I assume you are running a Walbro as well?
Old Dec 7, 2007 | 07:17 AM
eez's Avatar
eez
yes @ 52 PSI
Old Dec 7, 2007 | 07:20 AM
THE TECH's Avatar
THE TECH
yes @ 52 PSI
So then it isn't a fuel issue. Tuning or UTEC is the issue.
Old Dec 7, 2007 | 08:14 AM
Biochem7's Avatar
Biochem7
Regular
Which pulley are you using?
Old Dec 7, 2007 | 08:39 AM
eez's Avatar
eez
3.12 serp, 34 Jackshaft and 28T SC (upgraded from 32T)
Old Dec 7, 2007 | 09:08 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
thats why hes making the high psi. its his combo of pulleys that make the blower spin faster. Maybe get some large injectors?
Old Dec 7, 2007 | 09:58 AM
Biochem7's Avatar
Biochem7
Regular
Okay here is the obvious question. Why didn't you just get the 2.87 pulley?
Old Dec 7, 2007 | 10:00 AM
DMK's Avatar
DMK
Bigger pulley = better grip. The 3.12 + 34T is the same as the 2.87.
Old Dec 7, 2007 | 10:03 AM
jackie chan's Avatar
jackie chan
how are you tensioning the blower pulley? if its overtensioned(if thats a word) you will cause premature failure. you see it a lot with mustang guys using tensioner bolt down tighteners
Old Dec 7, 2007 | 10:15 AM
eez's Avatar
eez
same as stock, just an 1" smaller belt
Old Dec 7, 2007 | 10:21 AM
JET MECH's Avatar
JET MECH
sorry to here about the problems. the quickest way to check if the head unit has a compressor problem or bearing problem is to loosen the cog idler pulley, pull the cog belt off and turn the s/c cog pulley by hand. if you feel or hear any abnormal noises investigate further by pulling the air cleaner off (or in your case pulling your bumper and custom CAI off). and inspecting the compressor area with a inspection mirror. check for side to side play in the compressor rotor and scrape marks on the inner housing.good luck.
Old Dec 7, 2007 | 10:23 AM
eez's Avatar
eez
exactly
