Those who installed their own FI Kit
Old Dec 13, 2007 | 07:41 AM
superchargedg's Avatar
superchargedg
Damn Noobs
I installed my stillen s/c (all stages) and it was pretty easy......then i installed the greddy twins with the engine in the car.It was no fun at all doing it with the engine in the car but i did get it done with a lot of patience and a litle help from dave at functiontuned.
I would not even attempt it again unless i pulled the engine out first.
Old Dec 13, 2007 | 07:44 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Installing my Turbonetics was well worth it, saving $$$ and knowing every nut/bolt of your kit is nice. I would have installed the Greddy but the motor was blown so I didnt do that kit. When I picked up the car I felt silly not having installed my own kit.
Old Dec 13, 2007 | 08:28 AM
BhamZMan's Avatar
BhamZMan
Thanks for the input/encouragement everyone. I think this will make a good project for me at beginning of the year. Lucky for me I can find help on here should I get into a jam
Old Dec 13, 2007 | 08:43 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
if you have the UR underdrive pulley it will underdrive the sc and make less power. The stock will drive it fine and has a bit more mass. Ive heard it helps with the vibrations from the sc as well.
Old Dec 13, 2007 | 09:26 AM
App6MT's Avatar
App6MT
^ +1.
You would want to get a regular lightweight pulley at that point.
Old Dec 13, 2007 | 09:46 AM
coachk's Avatar
coachk
Originally Posted by App6MT
Did you pull your engine?
I really want to do the Turbonetics by myself and it should be no problem. But I want a TT setup more (not sure why cause I don't want a ton of power). I reeeeally want to do the install myself but doing the TT just scares me for some reason.
Yes...A friend of mine has a shop and a lift so it only took a couple of hours.
Old Dec 13, 2007 | 09:47 AM
phreaktor's Avatar
phreaktor
Design Engineer
Can't be done.
Old Dec 13, 2007 | 10:27 AM
BhamZMan's Avatar
BhamZMan
Thanks for the input, good thing I still have the stock pulley laying my basement.
Old Dec 13, 2007 | 03:42 PM
VIZAGE's Avatar
VIZAGE
IMO any SC or single turbo is worth doing yourself. Can be a pain like all kits offer. But very self awarding. I read over my instructions, seemed a hundred times. Didn't rush. Put together what I could before starting the hole project. Made a lot easier.
As TT go and from what I've seen in the shops is it's better to have them do. Some of the nuts on the manifold look like a pita, even with the motor out. Plus you can easily apply heat wrap to parts and lines already on the stock block.
Old Dec 13, 2007 | 03:48 PM
iStan's Avatar
iStan
ZR
Vortech... Go for it
Old Dec 13, 2007 | 05:02 PM
Blackbird CPV35's Avatar
Blackbird CPV35
I did my vortech tuner kit in 2 days with just hand tools. Its totally worth it and you learn alot about your car too
Old Dec 13, 2007 | 05:11 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Its definitely not very hard until you have those cheesy *** fuel line adaptors start to leak on you and spray fuel everywhere Well this is something we have seen when installing customer supplied used Vortech kits .
Old Dec 13, 2007 | 09:29 PM
jining's Avatar
jining
I installed my own APS TT tuner kit w/ CJM stage 2 fuel system in my garage on jackstands with hand tools... pros and cons..
Pros: I learned so much about my car I am glad that I did it. Took well over 30 hours to do the install. Frustrating, but being able to say you did your own install is priceless.
Cons: First time doing an FI install = many problems. I didnt preload the actuators right so that took another 5 hours to redo. I had an exhaust leak on the LHS Manifold, cost me 1k to have the motor pulled and my install double checked... (I didnt want to do it myself I was tired of it and frustrated at the time, + I wanted to have someone double check my work).
Other then that, all in all I would say that it made me 1000% more knowledgable... and I probably saved a few k worth of install money.
Old Dec 14, 2007 | 05:11 AM
04treefiddy's Avatar
04treefiddy
Well, man it took me and a buddy 5 1/2hrs to do my kit. I bought it used and then put 15k miles on it with no problem whatsoever. If you have any questions pm me and i will give you my number, since i am pretty close.
Also put the stock pulley back on the crank and go ahead and get a 3.12 pulley. Then go to sharif and get tuned.
Old Dec 14, 2007 | 07:23 AM
Zivman's Avatar
Zivman
I have installed a TT and a ST setup. I will not do another TT unless I pull the motor. I would not recommend anyone else attempt a TT install due to the potential problems which are almost infinite in number. A ST is very much easier, but still somewhat challenging. I still wouldn't advise a person to self install, but I would feel better about them doing a ST vs a TT.
Now as far as a SC setup, I definitely think it is doable. I would think you could get it done in a single day without rushing. I would think a shop would be more reliable, but if you have a bit of mechanical ability and the right tools, doing the install yourself should be no problem... it is more or less a fancy intake
Old Dec 14, 2007 | 07:28 AM
iStan's Avatar
iStan
ZR
That's what I tell everyone.. Uh, it's just a CAI...
Old Dec 14, 2007 | 07:31 AM
supra crazy's Avatar
supra crazy
i installed my greddy kit myself it was a bit of a apin because I bought the kit used so a few bolts where missing, but its preety strait forward...good luck
Old Dec 14, 2007 | 07:53 AM
  #38
teh215's Avatar
teh215
Originally Posted by Ahsmo
I would say its worth it. Everytime something does not seem right, you know what to look for rather than trailering the car up to the shop and have them look at it.
Basically, If something isn't right I generally know where to look.
Plus I had a good time installing my kit.
Exactly what I was going to say.
Old Dec 14, 2007 | 08:11 AM
  #39
coachk's Avatar
coachk
Originally Posted by phreaktor
Can't be done.
Not sure if this was reference to my post, but I meant it only takes a couple of hours to pull the motor.
Old Dec 16, 2007 | 11:06 AM
  #40
brickyardgreg's Avatar
brickyardgreg
installed my kit my self. definately research the install process find out the common trouble spots and how to get through them. a second set of hands will help alot. its good because you get to know every part of the kit and it will help when you have to service your ride. just dont cut any corners take your time and you wont have any issues. best of luck
