Blown again
Old Dec 14, 2007 | 12:24 PM
charged's Avatar
charged
Default Blown again
Trying to figure out why vortech is blown again. I sent to Vortech and they fixed bearings. It was reinstalled and ran great for a day. I shut car off and went to restart 2 days later and the noise is back and worse than ever. WHAT is going on?
Old Dec 14, 2007 | 12:28 PM
iStan's Avatar
iStan
ZR
When did you initially install it?
Old Dec 14, 2007 | 12:45 PM
Old School's Avatar
Old School
Shift_Boost
that sux....greddy twins ftw.
Old Dec 14, 2007 | 01:15 PM
sentry65's Avatar
sentry65
the burninator
that sucks. When did they work on it? Just a couple weeks ago?
btw where'd you dyno at?
438whp and 351 tq are some pretty good numbers for just the 3.12 pulley, JIC Y-pipe, and exhaust - unless I'm reading your mods list wrong
Old Dec 14, 2007 | 01:22 PM
WSchli1672's Avatar
WSchli1672
Dang that sucks is right. Who's doing your work on it?
Sentry, you have any problems with yours at all?
Old Dec 14, 2007 | 01:26 PM
sentry65's Avatar
sentry65
the burninator
not yet
had a jackshaft bearing go bad after about 2000 miles. That's been about it
I have about 9000 miles on my kit to date, 27K total miles on the engine
For me, if my blower actually went bad, I'd just trade it in for an Si-trim for $300 or whatever it is
Old Dec 14, 2007 | 01:41 PM
Hexxum001's Avatar
Hexxum001
Same here. Hopefully there will be no further issues with my SC but if it should go bad sometime down the line, I'll be upgrading to the Si trim too.
To the OP, that really sux bro. Hopefully Vortech will step up and take care of you here. Going bad again that fast is not good.
Old Dec 14, 2007 | 02:19 PM
WSchli1672's Avatar
WSchli1672
What would be the Si trim? Is that something new in the Vortech S/C?
I am planning on buying one pretty soon, as I am not going to put on the APS TT I had originally bought.
Old Dec 14, 2007 | 02:25 PM
sentry65's Avatar
sentry65
the burninator
Si-trim is a new blower vortech makes that seems to be slightly more efficient and is rated to rev to a higher max rpm than the stock SC-trim blower
why not go with the APS TT? looking for being CARB legal?
Old Dec 14, 2007 | 02:43 PM
WSchli1672's Avatar
WSchli1672
It's said forever that t was being going to be CARB legal, but never has happened. Haven't seen any updates on it since way back, when I bought it.
Wish it was, I'ld go that way, but CA just isn't that way.
Old Dec 14, 2007 | 02:45 PM
sentry65's Avatar
sentry65
the burninator
yeah IMO they never had a chance since they were replacing the fuel injectors
the JWT kit should have been the first turbo kit out of all the turbo kits to become CARB legal and it never did. It even used the stock injectors for the basic kit
Old Dec 14, 2007 | 02:51 PM
NS_350GT's Avatar
NS_350GT
^^+1
What engine management are you using? Injector size?
Old Apr 2, 2008 | 04:27 PM
charged's Avatar
charged
Well, S/C supposedly fixed. Vortech claimed that the impeller failed due to the cog belt being too tight. Is that possible? I think they are fos but I hope it doesn't blow again.
Old Apr 2, 2008 | 07:14 PM
TSG-Z's Avatar
TSG-Z
Man, I hope this doesnt happen to me! Good luck!
Old Apr 2, 2008 | 07:20 PM
turismo's Avatar
turismo
Damn good luck
Old Apr 2, 2008 | 10:16 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
If your tightening the belt too much, then you are definitely putting too much stress on the bearings, and they will fail quick. The tighter you've got the belt the quicker they will fail.
Old Apr 3, 2008 | 05:14 AM
jpc350z's Avatar
jpc350z
Which begs the question "how do you know when it's tight enough".. Vortech gives no advice or method for determing it..
Old Apr 3, 2008 | 11:00 AM
str8dum1's Avatar
str8dum1
it shouldnt squeal at start up. you should be able to turn the belt about 45- 60 degrees with 1 finger.
then do a logged pull and make sure that the boost is linear. i loosened mine almost 4 turns and still no slip. my bearings in my alternator and water pump thanked me.
Old Apr 3, 2008 | 11:03 AM
jpc350z's Avatar
jpc350z
I believe the discussion is with the cog belt..
Old Apr 21, 2008 | 05:33 PM
charged's Avatar
charged
Blew again? wtf
