Injected Performance: Cosworth dyno test at 7000+rpm FI
Old Dec 20, 2007 | 12:23 PM
r0mey's Avatar
r0mey
very nice
Old Dec 20, 2007 | 12:25 PM
rcdash's Avatar
rcdash
Originally Posted by RudeG_v2.0
Very nice. Glad to see something more substantial than we saw on the stock NA car.
What PSI were you running? And any plans to run a test with higher PSI?
Graph shows 16 psi. Solid gains over a broad rpm range!
Old Dec 20, 2007 | 12:29 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Injected Performance: Cosworth dyno test at 7000+rpm FI-homer-d-oh-.jpg I only took a quick glance and I totally missed that! I thought that was the torque curve at first.
Alberto's Avatar
Alberto
Cranky FI Owner
Id like to see this tested on a car without so much headwork, maybe just a set of cams. Im sure more tests will follow, I cannot judge this plenum based off of this review...
Old Dec 20, 2007 | 12:32 PM
doug's Avatar
doug
Attachment 171582 I totally missed that! I thought that was the torque curve.
if that was the TQ curve i would buy it in a heart beat
Old Dec 20, 2007 | 12:34 PM
D350Z10's Avatar
D350Z10
Originally Posted by Hal@IP
IP 4.2L, IP Stg4 Heads, BC 264 cams, SFR 60-1's, conservative pumpgas tune
IC, very nyce indeed but with a 3.5L and no headwork the gains would be quite less right???? How much do you think would be the projected difference?
Old Dec 20, 2007 | 12:37 PM
Kwame's Avatar
Kwame
Nice Work!
OT: That car has really nice headlights.
jonnylaw's Avatar
jonnylaw
https://my350z.com/forum/forced-induction/320934-injected-performance-cosworth-inlet-manifold-review.html
Old Dec 20, 2007 | 12:45 PM
D350Z10's Avatar
D350Z10
Originally Posted by jonnylaw
I saw that, but its low boost, on a TN kit, and a stock motor alot of variables there that will change the outcome.
Old Dec 20, 2007 | 12:48 PM
jonnylaw's Avatar
jonnylaw
I hear 'ya, I'm sure when the plenums are shipped to customers, they will be a lot of independent dyno testing on G's/Z's with full bolt-ons, but not built engines/F/I (hopefully).
Heck, I'll do one when I receive it.
Old Dec 20, 2007 | 01:05 PM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
What's the difference? It's not like they tested on stock heads / stock intake manifold.. They tested aftermarket heads w/ a stock manifold vs aftermarket heads w/ a cosworth plenum. The only variable in their testing was the plenum .
Old Dec 20, 2007 | 01:20 PM
D350Z10's Avatar
D350Z10
Very True^ chit I never saw it that way.... very good point.
Old Dec 20, 2007 | 01:50 PM
__jb's Avatar
__jb
Z + Rear Seat
Very impressive, guys! Good work!
Green car next?
Old Dec 20, 2007 | 02:13 PM
Julian@MRC's Avatar
Julian@MRC
So what if hypothetically my grandmother had *****? Would she be my Grandfather??
Seriously, there are way to many, "what if this" "what if that" comments.Look at the before and after tests. THE ONLY THING CHANGED ON THE SET UP WAS THE PLENUM. The plenum was the only reason for the HP increase in their testing. I tmakes power over a stock plenum, period. To speculate how much on particular applications is silly..
Nice gains..
Old Dec 20, 2007 | 02:18 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
he-she would be gross that's for sure
Old Dec 20, 2007 | 02:20 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Injected Performance: Cosworth dyno test at 7000+rpm FI-commentlarry.jpg
Sig worthy material right there!
Old Dec 20, 2007 | 02:33 PM
SpoilsofWar's Avatar
SpoilsofWar
Thanks for the research IP. That is an impressive gain.
The only thing I would like to have seen was a 3 way comparison - Stock vs. Spacer vs. Cosworth. There is no question that the Cosworth makes power over stock, but now we're left to wonder how much more power it makes over a modded stock plenum. Simply so we can figure the cost / benefit ratio.
Old Dec 20, 2007 | 02:37 PM
  #38
Crom's Avatar
Crom
^ The APS tallboy gains are very similar...but I like the looks of this one much more. Plus you can retain a beefier strut bar.
Old Dec 20, 2007 | 02:46 PM
  #39
se-r / gti-r's Avatar
se-r / gti-r
Nice test.
Id like to see the plenum on a stock motor with a Greddy kit.........just like my set-up
Old Dec 20, 2007 | 02:48 PM
  #40
XKR's Avatar
XKR
I have never seen these kind of gains from a spacer
Nice gains..
Thats what I am talking about.... I am just glad I ordered this thing before the stampede starts.
Today we performed back to back dyno tests on the Cosworth plenum vs stock. It is clear where the Cosworth plenum truly shines... forced induction, as many have suspected. Giving up virtually nothing, this manifold yielded an impressive 30-40whp gain from 5200-7200rpm.
All I can say is thanks guys for shedding light on this thing.
