Spark Plug Gap & Analysis
Old Dec 27, 2007 | 06:15 AM
moog's Avatar
moog
Default Spark Plug Gap & Analysis
I keep reading conflicting things with spark plugs gap. I hear some say stock gap (.044) is fine for FI applications while low boost (under 10). While others say to decrease spark plug gap to .028.
Also, does take pics of their plug tips after removing them? I have 4 that I just removed that look very similar, while two look slightly different.
Old Dec 27, 2007 | 11:51 AM
QuadCam's Avatar
QuadCam
checking plug tips only works if you shut the engine off immediately after a run. I mean IMMEDIATELY!!!...............like as soon as yuo cross the 1/4 mile finish line. then you just coast the car back to the pits to analyze the plugs.
Old Dec 27, 2007 | 12:10 PM
moog's Avatar
moog
gotcha...I guess the same would apply on the dyno.
Old Dec 29, 2007 | 08:09 AM
Q45tech's Avatar
Q45tech
Engineers sample the secondary voltage and look at the waveform with different plug gaps under highest load to arrive at a starting gap so that at 60k-100k things still function from wear down. Since WOT acceleration requires the highest voltage [~~22-25KV depending on electrode diameter] important to look at voltage under these conditions.
http://www.picotech.com/auto/wavefor..._ignition.html
Labs use a pressure sensor that looks like a metal washer with a wire attached to measure peak pressures as the spark plug stretches minutely.
http://www.optrand.com/PSIplug.htm
http://www.ngksparkplugs.com/techinf...stallation.asp
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
