Symptoms of possible utec failure.
Old Jan 22, 2008 | 09:35 PM
DaveFunction2ND's Avatar
DaveFunction2ND
Originally Posted by superchargedg
We figuerd it out...the original cat convertors burnt up and caused all the smoke and they also fried my wideband o2 sensor.I have experienced all kinds of problems in my 30 years in this business but have never seen or smelled a cat convertor burn up like these did.
So now im gonna get a new wideband sensor and 2 new post o2 sensors just to be sure and replace them........see you next week for the higher boost tune dave.
Glad we got it figured out Keith! When you called and told me everthing that was going on this was the only thing that made sense.
Old Jan 22, 2008 | 09:36 PM
DaveFunction2ND
Originally Posted by rcdash
The cats likely run much hotter than your turbos. Cats burning up is a symptom of running rich, and not so much being subjected to heat from a turbo per se. Of course, when you have a turbo, you run a little richer than you usually would. Metal cores survive FI better (if you decide to pursue cats)...
EDIT: I don't know anything about your build, but if you take the cats out, you may want to examine the tune (AFR).
He's at ~11.5:1. Its more of an issue that the auto is in boost almost ALL the time.
Old Jan 23, 2008 | 01:29 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Thanks for the help dave and the test pipes are going on sunday and ill see you thursday.
Old Jan 23, 2008 | 06:01 PM
rcdash's Avatar
rcdash
Other auto high performance turbo cars (Porsche, the new GTR) somehow manage to run with cats. I'm hoping it's possible without losing too much power, cause I'm going to commit to the move from test pipes to custom cats (200 cell metal cores w/ 3.5" inlet/outlet welded into APS test pipes)...
Old Jan 23, 2008 | 06:38 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Your car on low boost is making more power than the new GTR...I think its very doable...fairly high power through cats. It will be interesting to see what AF ratio that GTR is dialed to.
Old Jan 23, 2008 | 07:16 PM
theking's Avatar
theking
See it in this thread. https://my350z.com/forum/showthread.php?t=326073
pslamp32
Feb 8, 2017 09:07 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
