Turbo automatics...
Old Mar 27, 2008 | 11:23 AM
  #41
coachk's Avatar
coachk
Originally Posted by Si3lv5er0Z
this may be a dumb question, but if u just did the VB, TC, and cooler u "should" be ok with the 5AT on a turbonetics single turbo setup???
JUST DO IT...You'll be happy you did.
Old Mar 27, 2008 | 11:30 AM
  #42
iStan's Avatar
iStan
ZR
^Word.
Question, so will these built trannys handle road racing abuse or is it primarily for the drag guys?
FI for about 10K with 0 issues. Cooler installed about a month after FI
Old Mar 27, 2008 | 01:05 PM
  #43
MardiGrasMax's Avatar
MardiGrasMax
should be ok, yes
Old Mar 27, 2008 | 01:43 PM
  #44
BlueZ Brother's Avatar
BlueZ Brother
Custom Title.
I was thinking toward going F/I sometime myself. I've heard from some buddies that the stock A/T should be good to 450 or 500 with no upgrades but definitely plan to run an upgraded VB and TC just to be sure the transmission can put the power down reliably.
I planned on using a Turbonetics setup on a stock motor at a slightly conservative 7.5 psi, which is what I'm told is pretty near the safe limit for the stock VQ35, and I suspect an upgraded VB and TC should have no problem with this. If you're running crazy numbers with a twin turbo and built motor, a fully built transmission is a must to ensure drivetrain durability, I'd imagine.
That said, I'm in the same boat looking at possible transmission upgrades, and am leaning towards SGP at the moment.
Old Mar 27, 2008 | 02:35 PM
  #45
coachk's Avatar
coachk
Originally Posted by istan
^Word.
IIRC there were a few guys with the built trannies that went out for fun and tracked their cars with no issues. Maybe they'll chime in with their experiences. I think GTM had a customer do this as well.
Old Mar 28, 2008 | 04:12 AM
  #46
350zHalleck's Avatar
350zHalleck
This thread has been very helpful thank you everyone for the info. I was in the shop last night looking a budies car and a couple months ago I picked up an S4 and love the way a turbo car feels to drive. now I have the itch to throw a turbonetics kit on the Z. I swear it is a disease. but I don't want a cure.
Old Mar 29, 2008 | 06:16 AM
  #47
roncfpz's Avatar
roncfpz
^Word.
That depends on the amount of boost you're running and ambient temps at the track. For any sustained hard road racing at higher temps the fluid will quickly reach excessive temps and the trans will go into safe mode. Maximum trans fluid cooling is an absolute must.
Old Mar 31, 2008 | 11:30 PM
  #48
g35driver2003's Avatar
g35driver2003
Originally Posted by Audible Mayhem
we have stock block autos trapping 116 to 124 all day.
you will need to upgrade the valve body and probably the tq convertor...
I bet I will need to upgrade in the future if not very soon
Old Apr 1, 2008 | 01:25 PM
  #49
Murfdizzle21's Avatar
Murfdizzle21
i wanna go turbo, prob turbonetics or APS ST, but my ride is my daily. i got nothing else... my friends are like just do it, if u blow ur motor call people for rides... lame.
Old Apr 1, 2008 | 04:55 PM
  #50
DanielW's Avatar
DanielW
what kind of boost spikes do you other auto tranny turbo guys see between shifts?
Old Apr 1, 2008 | 05:34 PM
  #51
MardiGrasMax
I havent logged a full 1-2-3-4 run but on the 3-4 shift I go from 7.7psi to 8.4psi and back down to 7.8psi in about a 1/2 second. The 8.4psi peak only shows on my log for 1/10 of a second. This is on the waste gate springs. I can live with that. I'm still tuning AFR so ignition timing is soft for now, if that has any effect on it I dont know.
bcoffee20
Nov 19, 2015 06:39 PM
