Powerlab Question
Old Feb 7, 2008 | 05:03 PM
G3po's Avatar
G3po
Default DP and front brace.
Originally Posted by INTENSEPOWER
Sir,
There's 4 o2 bungs in the PowerLab kit for the 4 factory o2 sensors. There's also a 5th o2 bung (pre-plugged) which the end user can use for an aftermarket wide band. So the answer is YES. Hope this helps.
Darrren
Hereare a few questions:
1) How does the PowerLab kit bolt up to the exhaust? At the beginning of the OEM mid-pipe?
2) Does the kit retain the front bumper brace?
3) Can one, obtain an install manual before purchase?
Thanx
Old Feb 7, 2008 | 05:11 PM
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
Hello,
Answers:
1. It mates to the the oem/factory rear section. Therefore, you will need a rear section exhaust. I.E. -- JiC, Apexi WS2, etc.
2. Yes, but it requires that a portion of it be cut. Instructions to that end are included.
3. Yes, once the kits are officially released -- PowerLab has informed us that they're ready to pull the trigger by the end of this month.
Hope this helps.
D
Old Feb 7, 2008 | 05:47 PM
Floridaboy1605's Avatar
Floridaboy1605
So all i would need for say would be the aam single y pipe back exhaust and ill be good???
Old Feb 7, 2008 | 06:44 PM
SlideFox's Avatar
SlideFox
D,
Has Powerlab released any photos of the kit from the rear of the engine? To show the DP, and the front section of what would be part of the exhaust?
Old Feb 7, 2008 | 06:59 PM
jeffie7's Avatar
jeffie7
Sir,
Darrren
Wonderful. So does the kit replace the Y pipe or does it bolt up to the Y pipe? you state rear section exhaust so I'm guessing it replaces the Y pipe.
Old Feb 7, 2008 | 07:08 PM
9kFever's Avatar
9kFever
well I doubt they split the exhaust piping coming from the turbo into dual....I think its 3 inch straight piping from the turbo back to maybe the midpipe or rear section.
Old Feb 7, 2008 | 07:22 PM
jeffie7's Avatar
jeffie7
either way I have a JIC Y pipe, I agree, but he said rear section exhaust and most Z rear section exhaust bolt up to the Y pipe.
My guess would be no, I never thought it went past the Y, just trying to clear that up.
Old Feb 7, 2008 | 08:19 PM
SlideFox's Avatar
SlideFox
Maybe I can help with a verbal description. Yes, this kit would "eliminate" the Y-Pipe. So like Darren said, a Y-Pipe back exhaust would be recommended.
If you look at the picture above, you'll notice the larger pipe all the way to the right next to the gaskets. That pipe will come of the DP. If you notice towards the top of the pipe there is a smaller piece coming off it (it's a few inches long with a flange), that will bolt up to the long thinner pipe just to the left of it with the flex piece at the bottom end. That is the dump tube for the Tial wastegate. So if you can imagine like a "V" off the back of the engine. Hopefully that can give you a better visualization until Powerlab releases more photos.
Old Feb 7, 2008 | 08:27 PM
IIQuickSilverII's Avatar
IIQuickSilverII
if you are looking to have a true dual exaust you would probably have it hack it to make a rever "Y" pipe....
I think this kit whit the greddy Ti, JIC st or Ti, nismo ,RsR... amuse.........it would look bad as... plenty of options
Old Feb 8, 2008 | 09:57 AM
G3po's Avatar
G3po
Default More questions
Hello,
Hope this helps.
D
Will a "tuner" option be offered, sans injectors , UTEC and Walbro?
Thanx
Old Feb 8, 2008 | 11:49 AM
IIQuickSilverII
Thanx
its too bad the official release page is "read only"....this question would have been answered there
YES there is a tuner version(no injectors, ems, walbro)
Old Feb 8, 2008 | 12:40 PM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
+1 The Tuner Version will be $5700.00 + Shipping
Does not include
- Injectors (Deatschwerks 550-600cc)
- EMS (UTEC)
- Walbro Fuel Pump
Old Feb 8, 2008 | 01:32 PM
D-tuned's Avatar
D-tuned
what modification does this kit need to work on a 03 G35 coupe 6MT
Old Feb 8, 2008 | 02:12 PM
SlideFox's Avatar
SlideFox
This kit is already on the green widebody G. I believe the only modification needed is to one of the I/C pipes. The rest of the kit should bolt right in place.
Old Feb 8, 2008 | 02:29 PM
INTENSEPOWER
Hellos,
The G35 specific kits are next on PowerLab's agenda. They're looking at sometime in April (I believe) for release. Technically, however, the 350z kits could be acquired and the I/C piping modified, as SlideFox stated.
D
Old Feb 8, 2008 | 09:33 PM
xcessiveskllzz's Avatar
xcessiveskllzz
damn i have to wait that long before i boost my G...you guys owe it to me now(discount)..LOL
Old Feb 9, 2008 | 05:11 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by xcessiveskllzz
damn i have to wait that long before i boost my G...you guys oh it to me now(discount)..LOL
It would not cost all that much extra to modify the ic piping. MRC in NJ could do that for you I am sure for a reasonable rate.
Old Feb 9, 2008 | 09:26 AM
  #38
SlideFox's Avatar
SlideFox
^ +1
I'm sure if you called MRC or VTR, it would be a minimal charge to modify the I/C piping. I think it's only 1 pipe that has to be modified?!?! I'm sure it will be worth it!!!
Old Feb 9, 2008 | 10:03 AM
  #39
jeffie7's Avatar
jeffie7
I just dropped my front bumper (JP body kit) off at the body shop, they need to know the dimensions of the intercooler so they can make sure the front bumper cover fits before they paint it. I also need to know if there's any trimming involved in order to fit the piping.
Thanks.
Old Feb 9, 2008 | 10:04 AM
  #40
IIQuickSilverII
if you can fit the crash bar, then you can fit the intercooler
