HELP Misfire cyl #2
Old Mar 2, 2008 | 07:47 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Originally Posted by imonlykidden
I have greddy twins, and i have a p0306 cyl misfire, and we moved the coil to another part but the p0306 code still came up so it's cyl 6. What else could be wrong....we clear it, and it goes away, but once you drive it with out throwing it into boost the CEL comes on again, and it once again says p0306. anyone help.... i currently installed rc 650cc injectors, and switched out my e-manage blue with a utec. thinking it could be the ECU. well that was wrong.
HELP!!!
you pull the plug and look @ it? Swap it?
Old Mar 2, 2008 | 04:35 PM
diwun67's Avatar
diwun67
Good advice^^ The gap could be out of range...
Old Mar 4, 2008 | 10:47 AM
imonlykidden's Avatar
imonlykidden
Pulled the plug, looked at it it's fine. Though i did see the wires were pretty eroded from where the (not naming) shop had to splice the aftermarket injector plugs to the stock ones. well they just used electrical tape, and moisture got in there. i'm guessing this could cause a bad connection, no? Well i'm going to rip them down, re wire them, soder, and heat shrink the wires after i make a better connection. we'll see....any other ideas?
Old Mar 7, 2008 | 09:29 AM
imonlykidden
now cyl 1 misfires. wtf.
Old Mar 7, 2008 | 09:31 AM
imonlykidden
Check engine light is now blinking constantley.
nissan said i might want to get a engine compression check to make sure my pistons are not fawked up. anyone?
Old Mar 7, 2008 | 05:42 PM
Ep3's Avatar
Ep3
you didnt move the coils arround did you? perhaps switch the 2
derekinthez
South East
Sep 28, 2015 06:35 PM
ACP
Sep 15, 2004 08:07 AM
BATLtracy
South East
Aug 6, 2004 09:51 AM
braceman
Jul 21, 2004 02:04 PM
