HKS GT Supercharger
Old Feb 27, 2008 | 12:51 PM
  #61
ReV2Red's Avatar
ReV2Red
I haz da turbos
Originally Posted by Azreen Khan
out of the box will you will only get 300-310WHP - Im still using the original system HKS GT SC system with F-CON iS -- btw. I havent update my Dyno,
Just recently installed the JWT cams, Plenum Spacer, Pulley. Havet made the re-tune yet.
Ah right. That makes sense. Let us know what your new numbers are when you get it retuned. I'm eager to run a very similar setup to yours.
Old Feb 27, 2008 | 05:23 PM
  #62
MaRbLe's Avatar
MaRbLe
Originally Posted by ReV2Red
Maybe you missed the part where i mentioned everything in his thread?
HKSUSA claimed that number is possible on the stock setup with bigger injectors and a good tune from the dealer.
Once more people get the kit then we will see, until then is a "claim"...
Mine should be on by the end of March but it will not be in stock form.
Old Feb 27, 2008 | 05:28 PM
  #63
Azreen Khan's Avatar
Azreen Khan
Originally Posted by Cloud
off topic but which part of m'sia are you from? I'm m'sian too but in California right now.
Sabah, Malaysia. doing what bro?
Old Feb 28, 2008 | 03:03 PM
  #64
medstudent25's Avatar
medstudent25
so what kind of price is this going to run someone?
Old Feb 28, 2008 | 11:52 PM
  #65
ReV2Red's Avatar
ReV2Red
I haz da turbos
MSRP is going to be 6495 from HKS, but vendors will probably sell it for less.
Old Feb 29, 2008 | 05:24 AM
  #66
jonnylaw's Avatar
jonnylaw
u already ordered when its not released in the us yet??
Old Feb 29, 2008 | 09:57 AM
  #67
live2themaxuk's Avatar
live2themaxuk
It is in Japan, and has been seince end of last year
Old Feb 29, 2008 | 10:14 AM
  #68
jonnylaw's Avatar
jonnylaw
no kidding and it has been released in many other countries as well.
Marble's location is Idaho US, hence the reason I asked. Ordering from Japan from the US, would be considered "grey market" goods and would not carry a HKS USA warranty.
Old Feb 29, 2008 | 03:32 PM
  #69
MaRbLe's Avatar
MaRbLe
Yes, I should have the car back from GTM end of March.
Old Feb 29, 2008 | 03:42 PM
  #70
Jay'Z's Avatar
Jay'Z
Jonny.. So you bought the HKS SC???????? What whp u expecting?
Old Feb 29, 2008 | 03:46 PM
  #71
jonnylaw's Avatar
jonnylaw
I plan on buying it when the kit is released in the US for the rev-up engines, I dunno how Marble/GTM ordered one from HKSUSA
I'm aiming for 350whp with upgraded injectors and retune, but I'm not looking for monsta power, and a little less would be acceptable for my dd.
Old Mar 2, 2008 | 08:19 AM
  #72
Azreen Khan
Ive been using the HKS GT SC for the last 4++ months. Going for JWT TT 530bb. Next 3++ weeks. So I think I wont make the re-tune for the new items Ive installed. I think this is only the best way setup u can install in your car -- Since Im an AT Trans. xcept for Clutch, LSD, short shift..(For Manual Trans) etc
My current setup :-
HKS GT Supercharger (Complete Kits)
Tomei Headers & Downpipe
HKS Hi-Power Dual Exhaust
HKS Twin power DL II
SplitFire Twin Drift Ground wire
Stillen Oil Cooler - Koyo V Radiator
Okada Project Direct Plasma Coil
Unotrodox Pulley sets (Must Stock Size - Will match the OE belt HKS SC)
PowerLab Plenum Spacer (Waiting for Cosworth Intake Manifold)
JWT 256" S2 Cams -
JWT Valve Spring & Shim
Eagle Rods H-Beam
CP Piston 8.5.1 Low comm - Stock 95.5mm
Cometic Head Gasket 96mm
Toga Main & Rod Bearing
CJM Complete Return Fuel System
DeatschWerks 600ccs Injectors
Racing Spark Plugs PulstarT Pulse Plug Model: DG-1
ECU Re-Flash by ECUTEK Jpn
Valve Body Upgrade By (Speedforceracing.com - SFR)
Torque Convertor upgrade ( IPT )
JWT 530bb Kits - ( next 18 days )
AEM Tru - boost - Have bought it - I want very simple & easy
Old Mar 2, 2008 | 11:05 AM
  #73
jonnylaw's Avatar
jonnylaw
^^I'll trade you my cosworth plenum for yous HKS sc
Old Mar 2, 2008 | 05:13 PM
  #74
Azreen Khan
Whats wrong with the cosworth plenum?
will create a Linkage? If higher boost 15++ psi ?
any of u guys here has any NA dyno Result for cosworth plenum?
Old Mar 2, 2008 | 08:17 PM
  #75
jonnylaw's Avatar
jonnylaw
Nothing is wrong with the cos, I just want the HKS sc, is all
By linkange, do you mean leaks? Eaglentanggreen had a leak problem with high boost, but I'm unaware of anyone else that had a problem.
For Mrev2,spacer vs. Cos plenum comparison on N/A see:
https://my350z.com/forum/showthread....osworth+plenum
Old Mar 3, 2008 | 09:32 AM
  #76
Azreen Khan
Omg - the cosworth is beaten by the MD. in NA dyno.
How about in FI dyno Mrev & Cosworth?
Gonna think twice for the Cosi -- btw im using the Powerlab P.S.
I think still can handle for FI @ turbo applications
Old Mar 3, 2008 | 09:43 AM
  #77
jonnylaw's Avatar
jonnylaw
The cosworth shines on f/i applications
Old Mar 3, 2008 | 09:49 AM
  #78
MaRbLe's Avatar
MaRbLe
Going to be running the Cosworth with the SC, cant wait to see dyno results.
Old Mar 3, 2008 | 12:39 PM
  #79
jonnylaw's Avatar
jonnylaw
do u have a revup?
Old Mar 4, 2008 | 06:55 AM
  #80
jpc350z's Avatar
jpc350z
Which S/C?
