Finished installing uppipe. Open dumb WG
Old Feb 19, 2008 | 05:23 PM
  #41
doug's Avatar
doug
my car doesn't use a MAFS .. too bad i can't give you mine
Old Feb 19, 2008 | 05:32 PM
  #42
350 Rookie's Avatar
350 Rookie
what are you talking about, it doesnt use one? What happened to it? ITBS?!?!? ahaaha
Old Feb 19, 2008 | 05:34 PM
  #43
doug's Avatar
doug
HKS FCon
Old Feb 19, 2008 | 05:40 PM
  #44
weslutes's Avatar
weslutes
i dont think my throttle body is faulty. How much for the maf, and you arent tryin to sell me one thats already limping, are you. lol
but like i said, i gotta test all my sensors and ill get back to you guys tomorow. i dont exactly know whats wrong.
hehe... finally I can get rid of this MAF that blew my motor.
Oooops did I say that aloud? J/K come on...
Old Feb 19, 2008 | 06:07 PM
  #45
350 Rookie's Avatar
350 Rookie
hahahahaha. you're crazy man. lol. hmmm. fine. you send it, ill run a couple of tests and if its fine, ill send the money. if its done, ill send it bak.
Old Feb 19, 2008 | 06:20 PM
  #46
taurran's Avatar
taurran
Originally Posted by kevinapex
Sorry to run OT man!!!!
Turran thoughts? I helped Burn install this, hate to see spikes because of it!!
Kevin
If it works it works, just be careful with that ribbed sort of flex pipe. When ipcheck (former member here) did a full wastegate dump tube using that ribbed flex pipe, the ribs in the tube created so much turbulence in the dump that it couldn't flow the dumped exhaust gasses properly. They backed up in the piping and caused a boost spike.
Just be careful when using that stuff.
Old Feb 19, 2008 | 06:33 PM
  #47
kevinapex's Avatar
kevinapex
Thanks man, well cut off the flex and tig on a 45 deg.
Kev
Old Feb 19, 2008 | 06:58 PM
  #48
hr2burn's Avatar
hr2burn
Let's tig in a the flared part of a trumpet or a french horn perhaps?
BA-WAAAAA!!!!!
Old Feb 19, 2008 | 07:03 PM
  #49
kevinapex's Avatar
kevinapex
Ok... 45 deg. Tuba exit.
Old Feb 19, 2008 | 08:44 PM
  #50
weslutes's Avatar
weslutes
I was being sarcastic...
Now are you being sarcastic?
The MAF works fine, I've tried it on my car.
Do some tests or switch one out with a friend. If that's your problem I'll hook you up.
Old Feb 20, 2008 | 04:57 PM
  #51
350 Rookie's Avatar
350 Rookie
alright, my maf was actually acting up today.
According to alldata, at idle, my MAF voltage reading should be between 1.1 - 1.5 volts. Instead my reading was .4-.6 volts. That cant be right, right? Also, at WOT, my MAF voltage hit 3.~ at like 5k rpm.
Well anyways, i took it for a drive today and kinda slammed gears at WOT, and the car went into limp mode. So i took it in, took of the MAF and sprayed it with brake cleaner and blew it dry. Put it back on, and beat the hell outta my car and wouldnt go into limp mode. Idk what coulda been wrong. The MAF wasnt dirty, i just cleaned it for the sake of cleaning.
Also, i came to find out today that my oil return line was busted and i was gushing out oil everywhere and thanx to the weld breaking on my pevious TN pipe, part of my fan case was melted, just the edge of the case. the fans are untouched but if driven any longer, it woulda melted the fans.
other than that, i just pray to god my car doesnt go into limp mode when im driving down the track. hahah.
Old Feb 20, 2008 | 05:04 PM
  #52
doug's Avatar
doug
well i guess its good to hear you fixed your MAF problem
Old Feb 20, 2008 | 05:15 PM
  #53
350 Rookie's Avatar
350 Rookie
ya temporarily, i garauntee it will be back and haunt me once again. Just not now.
Old Feb 20, 2008 | 09:31 PM
  #54
weslutes's Avatar
weslutes
That's good it's fixed for now.
Old Feb 21, 2008 | 09:14 AM
  #55
350 Rookie's Avatar
350 Rookie
Dammit, my car did it again. I can't take this anymore. Street Wars are in 3 weeks. I need this up and running.
Old Feb 21, 2008 | 09:16 AM
  #56
350 Rookie's Avatar
350 Rookie
Also, like the other guy said about this deletion of maf through his EMS, is that only possible through standalone or can i do that with a utec.
Old Feb 21, 2008 | 09:25 AM
  #57
SpoilsofWar's Avatar
SpoilsofWar
Need a standalone, the UTEC needs the MAF since it still utilizes the factory ECU.
Old Feb 21, 2008 | 09:28 AM
  #58
350 Rookie's Avatar
350 Rookie
damn. i dont wanna get a haltech cuz its way to expensive for me. Anyone on this forum using an AEM EMS. i havent seen anyone talking about it? That seems to be a cheap yet still a good system.
Old Feb 21, 2008 | 10:10 AM
  #59
350 Rookie's Avatar
350 Rookie
Alright upon quick research, i found that ems doesnt make a wire harness for our cars. Haltech seems to be well known and used. IM kinda leaning towards the HKS fcon vpro. Any comments on this particular system?
Old Oct 30, 2010 | 05:37 PM
  #60
SIR_pierre's Avatar
SIR_pierre
can anybody tip me about where i can get relocators/ open wg?
