TN kit topping out
Old Feb 21, 2008 | 12:33 PM
Chudson coupe's Avatar
Chudson coupe
Default TN kit topping out
Why do I see a lot of guys with the TN kit topping out around 350whp? Is the main reason the injectors? I've done a lot of looking around but haven't been able to come up with a solid response. I know the tune has a lot to do with it, but what is the most anyone has seen from a stock block/stock exhaust TN kit, assuming tuned with an emanage ultimate or utec. And what have people been hitting with just upping to 600cc injectors?
Old Feb 21, 2008 | 12:39 PM
taurran's Avatar
taurran
I have no idea what you're talking about. I made 412whp on a dynojet with the 380cc injectors and reflash. Many others on here have made upwards of 380+whp with the included injectors and reflash.
If you're seeing people making less power with the default kit, they're either running a bit rich due to variances in the car or install, or don't have supporting mods to make more power. The reflash can adjust fuel based on MAF signal but not based on fuel pressure.
There are PLENTY on this board making 400+whp on the kit with a simple tune, or fuel system upgrade (injectors, RFS) an tune.
There was a car recently tuned at GTM with Turbonetics kit and built motor that made 520+whp. The kit can deliver with the right supporting mods.
Last edited by taurran; Feb 21, 2008 at 03:12 PM. Reason: I meant 380cc..............
Old Feb 21, 2008 | 12:53 PM
MIAPLAYA's Avatar
MIAPLAYA
Agreed heres my dyno at 9 PSI with the 380cc injectors the kit comes with:
http://turboneticsownersclub.com/turbos/350zdyno.pdf
in case you don't have Adobe thats 390 WHP at 9 PSI on a VERY rich 10.5:1 run..
Old Feb 21, 2008 | 12:54 PM
k6750gsxr's Avatar
k6750gsxr
close thread.....
Old Feb 21, 2008 | 12:58 PM
athenG's Avatar
athenG
You hit full boost (9psi) around 4700rpm?
Old Feb 21, 2008 | 01:02 PM
MIAPLAYA's Avatar
MIAPLAYA
Not on the road no. That was an early dyno from Turbonetics when the kit first went on my car. The car was running stupid rich (10:1 most of the power band) and they were messing with the car a bit. My car makes 8 PSI at or about 3500 RPMs. I have posted video of this several times.
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by k6750gsxr
close thread.....
+1
Old Feb 21, 2008 | 01:08 PM
athenG's Avatar
athenG
ok, I know you said you hit 8psi in the mid 3000 or even lower on certain situation.
Old Feb 21, 2008 | 01:53 PM
redline350ZZ's Avatar
redline350ZZ
My TN kit is being maxed out as we speak!
Old Feb 21, 2008 | 02:32 PM
down_shift's Avatar
down_shift
Originally Posted by taurran
I have no idea what you're talking about. I made 412whp on a dynojet with the 280cc injectors and reflash. Many others on here have made upwards of 380+whp with the included injectors and reflash.
You mean.. 380cc injectors right?
Old Feb 21, 2008 | 03:13 PM
taurran's Avatar
taurran
Yes, typo...
Old Feb 21, 2008 | 05:39 PM
Chudson coupe
I didn't mean to bash the TN kit, I just purchased one. I just want to make sure that I hit 390-400whp. I don't have an exhaust yet but I've heard that its still possible.
When I said topping out, I meant the basic kit with no other mods. I see a few guys with signatures that say TN with a utec and they only hit 360, theres one for sale in the marketplace that said 359 I think, and I was reading part of Taurran's huge write up about his kit and one member has 360 in his signature. I realize that the tune is critical, but if someone only hits 360 at 9psi, why wouldn't they go to a different tuner and see if they can get more?
Also, where is the best place to mount my A/F gauge, everyone says as close to the engine as possible, so I would assume on the up-pipe, but there are alot of guys that put it on the downpipe. Whats up with that?
Old Feb 21, 2008 | 05:43 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we have countless TN kits with 400 hp. dont worry about it...
Old Feb 21, 2008 | 06:02 PM
athenG's Avatar
athenG
Why would you mount your gauge close to your Engine? And who said you mount that close to your engine? Is that a typo?
Old Feb 21, 2008 | 06:11 PM
Chudson coupe
Yeah, its a typo, I meant the sensor for the wideband gauge, where I would weld the bing to the pipe, I know it goes on the top side of the pipe no matter where I mount it, but which pipe? I have AEM eugo
Old Feb 21, 2008 | 06:21 PM
taurran's Avatar
taurran
I'd put it on the downpipe as close to the turbo as possible. Mine is in the lower part of the downpipe before the exhaust.
Old Feb 22, 2008 | 04:42 PM
zcon's Avatar
zcon
i'll have 400+ by saturday ;-)
Old Feb 22, 2008 | 08:08 PM
Chudson coupe
zcon, why were you at 360 at 7.8psi? any special reason like a break in period or something else? And what will be making the difference to get you to 400?
Old Feb 22, 2008 | 08:18 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I wish I wasn't on my blackberry bc I would give u a HUGE red F! Close thread
Old Feb 22, 2008 | 08:24 PM
diwun67's Avatar
diwun67
I've got one of those "weird" TN Z's that hit 400+whp at stock boost tuned by Performance Factory...FWIW I have 650cc injectors and UTEC. Only change I made to the kit was a Tial 38mm wastegate, but that had no bearing on the number I hit...
