MRC first....Cracked Crankshaft..
Old Feb 22, 2008 | 04:54 AM
Oleg's Avatar
Oleg
Congratulations on setting the bar?
Old Feb 22, 2008 | 05:05 AM
Kuruma-san's Avatar
Kuruma-san
Nice display of honesty
Old Feb 22, 2008 | 05:51 AM
Philthy's Avatar
Philthy
Boost Junkie
+10000 Julian doesn't hide stuff like this...
My guess is the failure was a combination of things...
Good luck with the rebuild!
Old Feb 22, 2008 | 06:21 AM
Sean's Avatar
Sean
....just the midget ****.
Old Feb 22, 2008 | 06:25 AM
Julian@MRC's Avatar
Julian@MRC
I actually quite open about that too..
Old Feb 22, 2008 | 08:57 PM
IIQuickSilverII's Avatar
IIQuickSilverII
so jules..u getting the ati pulley now? or just stock on the rebuild
Old Feb 23, 2008 | 12:31 AM
rrmedicx's Avatar
rrmedicx
Just curious what EMS you were using to control the launch...not that it matters really...was that the VPro? (Like I said just curious.) 2 steppin' again Julian.
Whatcha gonna build this time?
Old Feb 23, 2008 | 04:22 AM
Julian@MRC's Avatar
Julian@MRC
We were running the HKS FCON V-PRO. But the EMS has nothing to do with what happened..More like the launch at 6500 off the launch control, which causes less than favorable conditions to take place within your engine. but allows the turbos to spool up at the starting line. Were guessing the harmonics and vibration along with the high RPM's caused the stock oil pump and crank to fail.
What "seems like a good idea at the time" isnt always the best idea in retrospect.
Have you narrowed down an EMS for your project Randy?
Old Feb 23, 2008 | 04:48 AM
rrmedicx's Avatar
rrmedicx
Still being worked on. Nothing final as of yet. I have a bit of time since I will be breaking in the new motor these next couple of weeks. But once I build it I won't be able to drive the car without a new set of brains... Sorry for the O.T.
P.S. I opted for the Fluidamper for my build just to minimize any risks.
Old Feb 23, 2008 | 05:11 AM
Julian@MRC's Avatar
Julian@MRC
Ill give you a good deal on an Fcon or Haltech
Old Feb 23, 2008 | 01:07 PM
pmohr's Avatar
pmohr
@ 'adaptive learning'...sometimes that's just how you gotta do it.
Interesting that it cracked the crank, though.
I remember one thread I've seen on the forums I come from, where a revup oil pump was broken into 4 seperate pieces:
http://forums.maxima.org/showthread.php?t=543644
http://forums.maxima.org/showthread.php?t=395667
I don't believe he had the crank checked out, but there was apparently no obvious damage done. Hope he doesn't mind me posting the pics :wall:.
So you're still thinking it was the impact in the donor car that took it down, or any possibility it was the launch control?
In any case, congrats on actually checking it out to be sure, I've seen many a shop that would just install a new oil pump, throw a few gaskets at the motor and call it a day. Of course, those shops weren't MRC
Old Feb 23, 2008 | 02:16 PM
Julian@MRC's Avatar
Julian@MRC
Yeah this is what the oil pump looked like on ours, so i would have had those cranks checked on those set ups.
After the carnage that took place in that motor, one would be nuts to reinstall the crank without checking it out fully.
Old Feb 23, 2008 | 02:44 PM
pmohr's Avatar
pmohr
Basically. Some shops, though...
Old Feb 23, 2008 | 10:07 PM
InZomniac's Avatar
InZomniac
i feel happ even more now to have gotten the ati harmonic resonater pulley
Like I always said. That or the fluidampr.
Old Feb 25, 2008 | 09:03 AM
DandyMax's Avatar
DandyMax
The first one was just pushing the stock block VQ30 & oil pump to see how far it would go, and didn't care if it went... and it seized bearings so no point on checking the crank. It was dirt cheap to toss that engine away and throw another one in when you're talking a VQ30...
The second engine was to try the revup pump because it was first thought the VQ30 pump was the problem... but still stock block, no work done to it (it's just a stop gap while the 3.5 is being built)... and that 3L engine is just sitting in the car over the winter, hasn't been pulled out/torn down yet.
I'd like to know exactly what caused Julian's failure though, if indeed the launch control is a factor that's disconcerting, because a lot of us that drag race like using it...
Old Feb 26, 2008 | 12:35 PM
Julian@MRC's Avatar
Julian@MRC
WE just picked up the old broken Crank from Weston Machine, and he said the cracks were actauly near 3 of the Rod journals, not the mains. He said it could be from simply making too much power on the crank over and over again. And it also could be from detonation or crank vibration. Now looking at the tops of our pistons, they are not pitted and show ZERO signs of classic detonation.
Which leads me to conclude, that the launch control killed our crank..The violent and irratic explosions inside the motor in an attemp tto spool up the turbos while standing still, caused the crank to vibrate and flex, crackig the oil pump and the crank..This is my offical diagnosis.
Discuss..
PS I wil ost pictures tommorow, I dont have time today to do so.
Old Feb 26, 2008 | 02:12 PM
Sean's Avatar
Sean
Is there an aftermarket forged crank on the market?
Old Feb 26, 2008 | 02:52 PM
  #38
GTM's Avatar
GTM
Vendor - Former Vendor
There sure is
-George
GT Motorsports
Old Feb 26, 2008 | 03:25 PM
  #39
Julian@MRC's Avatar
Julian@MRC
Originally Posted by George@GTM
There sure is
-George
GT Motorsports
George..Comon already man..Stop whoring in mt threads please..
Old Feb 26, 2008 | 07:14 PM
  #40
track1z's Avatar
track1z
Default hmmmmm
I don't think a new crank is needed,but a BETTER (balanced) stock crank. OEM is balance just enough to get threw 100,000 mileish.
