MRC first....Cracked Crankshaft..
Old Feb 27, 2008 | 08:17 AM
  #41
overZealous1's Avatar
overZealous1
so there wasn't a dampener on the motor? if not i would call that the main culprit with the abuse issues accelerate the failure. any type of metal and engine parts have a certain fatigue life when vibrated or twisted. the crank in an engine making that much power will flex quite abit on each piston firing, that needs to get softened/damped.
i have seen in other motors this effect happening near the middle of the engine also. even in my Z, when i pulled the motor apart after 20k f/i miles, the #3 bearing had the most wear out of all of them.
Old Feb 27, 2008 | 08:49 AM
  #42
rrmedicx's Avatar
rrmedicx
Question.
How much power were you pushing through that motor Julian? >600rwhp? >700rhp?
Would us lowly <600hp guys have to worry about something like this if we utilize that 2 step feature?
Also were you using drag radials or slicks?
Along with upgraded axles (Level 8)?
So the weakest link in the drive-train ended up being the crank. Interesting..
Old Feb 27, 2008 | 09:59 AM
  #43
gothchick's Avatar
gothchick
In addition to increasingly larger hp outputs, I'm thinking these harmonic 'problems' become even worse on a stroked engine, or one with an extended redline.
Old Mar 9, 2008 | 11:42 AM
  #44
Julian@MRC's Avatar
Julian@MRC
We just got our new crank back from the balancer..He balanced it and knife edged it like some of the PRO-STOCK motors he has worked on in the past.. We will be updating in the next 2 weeks...
Old Mar 10, 2008 | 11:05 AM
  #45
DandyMax's Avatar
DandyMax
I'm not quite convinced the 2-step can be blamed as the cause here, given what all was done to the motor/drivetrain and what conditions it runs under. Will be interesting to see what happens with the new crank plus dampener.
Do you plan on risking the launch limiter again with the new setup?
Old Mar 10, 2008 | 12:07 PM
  #46
Julian@MRC's Avatar
Julian@MRC
Im really stupid, so probably..
Old Mar 10, 2008 | 01:02 PM
  #47
r0mey's Avatar
r0mey
QFT
Old Mar 10, 2008 | 01:10 PM
  #48
Philthy's Avatar
Philthy
Boost Junkie
where's the pics of this new bada$$ crank?
Old Mar 10, 2008 | 01:19 PM
  #49
Russ@Z1's Avatar
Russ@Z1
bahahaha, at least you admit it openly.
Old Mar 10, 2008 | 01:22 PM
  #50
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
+1
Let see the new crank?
Old Mar 10, 2008 | 03:04 PM
  #51
Julian@MRC's Avatar
Julian@MRC
Charlie got it..polishing it up
10secapsttz
North East
80
Oct 6, 2005 04:14 PM
10secapsttz
Tuning
22
Sep 23, 2005 12:06 PM
j's350z
North East
May 19, 2004 04:45 AM
