Any Running 3.5" Test Pipes to Greddy TT?
Old Mar 1, 2008 | 04:20 AM
Barzten1's Avatar
Barzten1
Default Any Running 3.5" Test Pipes to Greddy TT?
Ordered my APS 3" exhaust, 3.5" test pipes and a Greddy TT kit. Will the APS 3.5 testpipes fit to the Greddy manifolds? Thanks for any help.
Old Mar 1, 2008 | 05:36 AM
captj3's Avatar
captj3
The aps 3.5 test pipes won't fit the greddy turbos.
Old Mar 1, 2008 | 06:16 AM
westpak's Avatar
westpak
SFZCC
nope
Old Mar 1, 2008 | 06:23 AM
coachk's Avatar
coachk
You may want to cancel those test pipes real quick or just go with the APS TT instead and cancel the Greddy kit.
Old Mar 1, 2008 | 06:25 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
get ready for some extensive fabrication work...i would just get SGP's or AAM's man. save you some headache and money
Old Mar 1, 2008 | 07:16 AM
maximumsportZ's Avatar
maximumsportZ
APS wont bolt up to those greddy turbos.
Old Mar 1, 2008 | 07:29 AM
rcdash's Avatar
rcdash
ForgedPerformance modified the APS 3.5" for my JWT kit and it definitely looked like a lot of customization was done to get it to fit. I don't think he could do it remotely for you (and be certain of fitment), but you could ask...
Old Mar 1, 2008 | 07:50 AM
coachk's Avatar
coachk
Chris...did you get my PM??
Sorry OP.....
Old Mar 1, 2008 | 09:53 AM
westpak's Avatar
westpak
SFZCC
different animals APS and JWT are internal wastegate while Greddy is external
Old Mar 1, 2008 | 10:50 AM
QuadCam's Avatar
QuadCam
The greddy has a small 1.9" outlet with a 3bolt flange and NO internal wastegate.
The flange on the APS is huge de to the internal wastegate. Pus, the turbos aren't going to be located ont he exact same location.
You are in for a small PITA if you decide to keep and modify those downpipes.
Old Mar 1, 2008 | 02:36 PM
Barzten1's Avatar
Barzten1
What are some of the top dog test pipes I can make fit with this? I cant believe my project is waiting on testpipes.
Old Mar 1, 2008 | 02:53 PM
eltness350's Avatar
eltness350
The Untouchable
aam 3inch..with dumps....thats what im doin......
Old Mar 1, 2008 | 02:55 PM
Barzten1's Avatar
Barzten1
I was just looking at those. Will I be able to run them without an ebc? Man they are expensive but Ive gone this far. Have you heard them or seen them yet?
Old Mar 3, 2008 | 07:29 AM
Barzten1's Avatar
Barzten1
Any more input for me? I want to get these in the mail today. Will APS 2.5" test pipes work? What are SGP's?
Old Mar 3, 2008 | 09:22 AM
Barzten1's Avatar
Barzten1
Those SGP are a pretty penny. Im way over budget.
Old Mar 3, 2008 | 02:15 PM
thawk408's Avatar
thawk408
If you are not shooting for the moon on HP then the reg aps 2.5 will be fine. Promise.
Old Mar 3, 2008 | 03:05 PM
QuadCam's Avatar
QuadCam
plus you'll need to have an extra bung put in for your wideband O2. Also, I found the weld at the turbo outlet on the SGP down pipes needs cleaing up. I ended up spending another $75 getting my SGP downpipes into the proper shape that I expected them to be in. The inlet flange on the SGP was 2", but the pipe that is welded to the flange only had a 1.8" inlet diameter. I had to have my welder add some more weld on the inside and outside so that he could grind everything smooth and get rid of the turbulance caused by the 1.8" lip on the inside of the flange.
Old Mar 3, 2008 | 03:17 PM
Barzten1's Avatar
Barzten1
Thanks. Thats what I ended up ordering so I feel better.
Old Mar 3, 2008 | 03:20 PM
pmohr's Avatar
pmohr
Is that your Z with the twin disc Carbonetic setup in the shop?
Old Mar 3, 2008 | 03:23 PM
eltness350's Avatar
eltness350
The Untouchable
lol no....its the IN MY GARAGE 2 FEET IN THE AIR SINCE LAST SUMMER Z....
