highest whp on PUMP GAS ONLY (91 octane specifically)
Old Mar 3, 2008 | 07:50 PM
accordfreak's Avatar
accordfreak
Default highest whp on PUMP GAS ONLY (91-93 octane specifically)
Ok so I searched around for PUMP GAS only whp (no meth, no c16 etc etc) but I couldn't find that many. I looked in the thread where a bunch of people posted their setup but almost nobody put what kind of gas they were using.
I saw the stroker thread with pump gas only but that one doesn't count
I am looking for the most WHP with PUMP GAS ONLY (91-93 octane specifically)
I feel that anybody can just throw in race gas to tune to make big numbers but to make big numbers on pump gas only is a challenge.
if you could also list your motor setup, that would be great too.
1) whp on pump gas (91-93 octane) (please specify what octane for the east and west coast people)
2) built motor specs
3) type of turbo kit
4) fuel setup
thanks
Old Mar 3, 2008 | 07:53 PM
maximumsportZ's Avatar
maximumsportZ
Sorry I'm lazy. Probably not the highest but it's a start..
Numbers in sig, pump gas 93oct 17psi. Tuned by Jeremy @ Performance Factory.
Old Mar 3, 2008 | 07:58 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
The highest I personally know of on 91 octane is bverschage's Z that made 550whp on only 12psi with a Greddy TT. That car is badass and one of the sickest Z's I have every seen. The new owner is very lucky.
https://my350z.com/forum/showpost.ph...30&postcount=1
Old Mar 4, 2008 | 02:52 AM
Bullitproof's Avatar
Bullitproof
601whp 603trq, 93 octane 18psi.
cj motorsports stage 1 rfs
scotts cams which are about 240 duration(way less than jwt cams, but i also have a butter smooth 850 idle=)
click on sig and scroll down for dyno.
Old Mar 4, 2008 | 03:50 AM
TruBluZ's Avatar
TruBluZ
We only have 93 out here.
Old Mar 4, 2008 | 05:13 AM
SlideFox's Avatar
SlideFox
I think he said 91 Octane.... Where the west coast people at?
+1 Rude, I think Brian's is the highest I know of. It's fast.... I've driven in it!
Old Mar 4, 2008 | 05:16 AM
doug's Avatar
doug
i'm not at liberty to say but its higher than 602 rwhp 617 rwtq
Old Mar 4, 2008 | 05:32 AM
SlideFox's Avatar
SlideFox
On 93 Pump?
Old Mar 4, 2008 | 05:38 AM
doug's Avatar
doug
Originally Posted by SlideFox
On 93 Pump?
Si
Old Mar 4, 2008 | 05:44 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Si
probably stroked
but ... with the TT kits and the build engine you shoudl expect. ... about ~540-560whp stock stroke.... ~600-620whp stroker kit ....on pump gas(no meth)...
Old Mar 4, 2008 | 05:46 AM
cp2's Avatar
cp2
Didnt sunoco used to have 94 octane gas recently?
Old Mar 4, 2008 | 05:56 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Not to start a dyno debate, but your question's results can and most likely will be skewed at best.
Before my car lost a bolt from one of the manifolds to the turbo, I was making a ton of power and there wasn't even any timing added nor had we decided if that were to be the high boost setting.
Luis car (eagletanggreen) is going to be way up there as well.
Old Mar 4, 2008 | 05:58 AM
SlideFox's Avatar
SlideFox
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Wongy's G35:
718whp on 92 octane pump gas only (link)
IP 4.2L Stroker, IP Heads, BC Cams
Twin 67mm turbos
APS twin pump hanger, IP fuel lines & rails, 1200cc injectors
Daily-driven tune with Haltech Platinum pnp standalone
Old Mar 4, 2008 | 06:00 AM
craigo'sznprgrs
Originally Posted by Hal@IP
Wongy's G35:
Twin 67mm turbos
That's awesome!!!
Especially with the DD vs. DJ!
Old Mar 4, 2008 | 06:02 AM
SlideFox's Avatar
SlideFox
Wongy's G35:
Twin 67mm turbos
Wongy's G is awsome, but....
Stroker!
Old Mar 4, 2008 | 06:05 AM
Dynosty's Avatar
Dynosty
Stroker!
....details
I envy the viper guys who are putting down 4 digits on pumpgas!
Old Mar 4, 2008 | 06:07 AM
SlideFox's Avatar
SlideFox
....details
Ahmen!!
That was the only time I have ever been scared in a car on the street!
Old Mar 4, 2008 | 06:15 AM
doug's Avatar
doug
probably stroked
no stroker.. 3.5 .. dual pumps and a sweet fcking tune on 93
Old Mar 4, 2008 | 06:16 AM
IIQuickSilverII
nice...time for everybody to crank up the boost ....... and pull a shlt load of timing
