Throttle and RPM wires?? Where do you tap them?
Old Mar 7, 2008 | 09:42 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Default Throttle and RPM wires?? Where do you tap them?
As the title says, where do you tap these wire?
or Should I just swipe and hope someone finds it
Old Mar 7, 2008 | 09:52 AM
athenG's Avatar
athenG
Did you try calling or PM'ed CinMotorsports? I think they were the one who installed Daniel's AVCR. I know most shop usually keep it to themselves but might work since you are really not local.
Old Mar 7, 2008 | 10:30 AM
KPierson's Avatar
KPierson
You can get them both at the ECU. For RPM tap a fuel injector (if your device can work on 1 pulse per revolution signal).
Old Mar 7, 2008 | 10:51 AM
SpoilsofWar's Avatar
SpoilsofWar
Check nitrous subforum, I believe they have all the ECU pin info in there.
Old Mar 7, 2008 | 11:08 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Thanks guys.
Old Mar 7, 2008 | 03:57 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
For an 03 Z:
The throttle position wire is green and is pin 50
The RPM wire is white and is on the AC box under the radio
incase anyone found this thread later...other years are different
Old Mar 7, 2008 | 04:54 PM
athenG's Avatar
athenG
/\ I guess I'm going to do my own research since every year is different. I have an 05 G35 (Revup)
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
