New Week.... New Problem
Well I gave my engine bay a bath in Simple Green, hosed it off and took it out. I got on it and went through the gears several times and the dipstick didn't pop out like a champagne cork.
All the hoses were hooked up correctly.
That was some scary sh*t. I thought I blew another engine!
JET
JET
Wow. . .my dad and I custom fabbed an ATI procharger kit built for an 88 camaro to my '94 F-150 (4.9L I6). The same thing happened to us while driving form CT to Colorado. . .while we were in Nebraska. Talk about scaring the shytes out of us! Turns out the rubber grommet on the valve cover was crumbling inside and plugged up the vented PCV hose, and then eventually loosened up enough and blew out. I lost about 2 quarts of oil with a TON of smoke. I wonder if the check valve in your filter is disintegrating and floating around plugging up "important stuff?"
Good luck!
Good luck!
I am beginning to think our cars need a crankcase evacuation system, like most high HP supras have. They take the PCV valve out and replace it with a -10 fitting. Then on our cars, run both lines from both valve covers to a catch can that then run to the turbo intake pipe. I think this would help get a lot of the pressure out.
Originally Posted by Audible Mayhem
crankcase vacuum pump would be another idea...
I also need to figure something out, becuase my oil fill cap keeps on poping off.
Originally Posted by taurran
I talked to a guy in Miami that's running a custom single turbo and they did this, but routed both to the intake manifold. They even talked about drilling a port in the back of the passenger side valve cover for excess ventilation. I didn't get more details but it sounded interesting.
That seems like a good idea. I guess the greater vaccum from the manifold would help more then the turbo intake pipe?
Originally Posted by jkenefic
The new ARC V2 catch can is routed this way... Both the PCV and breather go to the can and the turbo provides the suction. Works very well.
I am more talking about removing the PCV completely and replacing it with a -10 fitting.
I had my oil changed at Sutherlin Nissan in Ft Myers last week and the idiots forgot to fully seat the Dip stick and while going over Cape bridge to head back home I went WOT and noticed a ton of smoke coming from the rear of my car as well. Once I got home I noticed the same thing oil all over the inside of the my engine bay. They didn't seat the dip stick properly and it blew out making a huge mess.
I have seen this before when you just don't have the dip stick pressed in all the way and it was never actually seated properly.
If it was, you have a crank case pressure problem... Do you run a catch can system? If not I would highly suggest you add one!
Originally Posted by JETPILOT
Well my dipstick episode has not reappeared. So I think I forgot to seat the dipstick properly.
JET
JET
JET
JET
