Dimming Innovate DB Gauge
Old Mar 30, 2008 | 12:36 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Default Dimming Innovate DB Gauge
I know there is a dimming feature on the DB, but it wasn't hooked up when they installed it. I found the wire, but were can I tap it in too?
Old Mar 30, 2008 | 03:03 PM
JonnyC's Avatar
JonnyC
I just wired mine up yesterday, and was able to tap into the parking light wire in the driver's kick panel. I thought I was going to have to run a wire from the fuse block in the engine bay, but luckily I was able to find this one.
I referenced this thread to figure out the color (sticky in the Audio Video forum) https://my350z.com/forum/audio-and-video/171725-wiring-color-code-guide-for-350z.html. This thread should also be moved there or to the Interior forum.
Here's some pics to help you out though...
Driver's kick panel, above the fuse block
Red w/ Blue stripe
Had to cut some of the zip ties holding the loom because it was very hard to bend (one noted in yellow, one further up as well). It's also pretty hard to get a screwdriver up there to pop the clip loose
Old Mar 30, 2008 | 04:18 PM
Blwn_By_Twins
You are the ****!
Old Mar 30, 2008 | 08:42 PM
JonnyC's Avatar
JonnyC
Glad I could help Oh, this was on a '03 btw, so the wire color might be different on other years.
Old Apr 18, 2008 | 03:34 PM
TayTaythatsme04's Avatar
TayTaythatsme04
sorry to bump this thread, but can't you just tap the illumination wire for dimming?
T
Old Apr 19, 2008 | 07:54 AM
JonnyC's Avatar
JonnyC
In the manual it says not to hook it up to a rheostat controlled power source...which is what the illumination wire is i think.
Old Apr 19, 2008 | 03:33 PM
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
T
Personally, I have not installed gauges in a 350z. With other cars (Supra), If you hook up to the dimmer switch it will do the opposite of what you want. We used a resistor.
Here is a link.....
http://forums.vwvortex.com/zerothrea...ostid=36130175
Old Apr 25, 2008 | 02:33 PM
Blwn_By_Twins
For reference, hooking it up to the wire JonnyC showed does work on the 03-06.
Old Apr 25, 2008 | 05:36 PM
JonnyC's Avatar
JonnyC
^ glad that worked for you. I actually posted that up before I even tested the gauge with my lights on, haha. Tested it the next day to make sure it worked.
Old Apr 25, 2008 | 05:40 PM
Blwn_By_Twins
It doesn't dim it very well though. I'm thinking about throwing a little tint on it. LOL
Old Apr 25, 2008 | 10:32 PM
JonnyC's Avatar
JonnyC
I agree. I was like..."wait...that's it?!" Tint would be a good idea. We'll see how much it bothers me first though.
Old Apr 26, 2008 | 05:32 PM
TayTaythatsme04
ok I used my car for the first time after the install and the gauge still dimmed using the Illumination wire, but it this is very bright at night
T
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
