Built Z with T-Trim Tuned!!!
Awsome!!! good job, it looks like the 350z vortech community is starting to figure these things out to put down some decent power!!! hopefully i will be the next one to post some good numbers!!!! bye the way thank you again floridaboy1605.............
Ahh so you are using 34/28 pulleys.
Maybe my Si isnt that far off in power then as I'm only using 32/28 with higher compression pistons.
AT least your motor is strong and reliable. I doubt the T-trim is worth the huge cost over my Si, esp for only 30 hp, esp with the stock block
i'm definately doing cams with my built block. that should put it close to the 500 club.
. i'm definately doing cams with my built block. that should put it close to the 500 club.
Def man im starting a cog pulley setup for the front now so im hoping to be in the 500 club here shortly??!! the ttrim is a little better than the si trim for low level boost but you have to remeber if u go higher boost the ttrim is going to be able to handle it!!
man, you should stop messing around and put a 2.87 on there, like TODAY!!
you spent more than a few grand on a built motor, now lets see some real #s!!
whoo hoo!
how advanced is your timing past 5k rpms? 20 degrees,.. more?
whoo hoo!
whoo hoo!
whoo hoo!
Hey man, rode in your brothers z last night, that thing was f'in fast..... can't imagine this thing, hope to take a ride in this bad boy soon...... congrats on the the build !!!
