upgrade to Vortech 3.12 pulley
Old Apr 15, 2008 | 10:06 AM
OldManZ350's Avatar
OldManZ350
Originally Posted by booger
Tim
I had heard you got by with out flashing the ECU . Maybe because you have 440's . I tried and tried with the 550's but I could never keep an idle for long . The ECU kept adjusting on its own . BUt as far as a piggyback go's......with all the problems Ive heard about from all the other piggybacks....the SS box is trouble free . Its simple , easy to tune , and it works well enough
Their is a bit of a trick for the Idle, setting up the cell value correctly in the 500-1000rpm from 0 to -5.1Hg and then blend to -28.5Hg. If the cell values are out of range, the O2 sencers can not do their job and the ECU will be constantly changing to try and maintain Idle and 14.7 A/R. But it can't so you get an eratict Idle. Some people have said that the SS BOX does not control Fuel in closed loop..... Cell Value must be correct in Vac and well as Boost. Any tuner that just tunes a car for WOT is not a Tuner, their just a guy what dyno to take your money. A real Tuner, will tune a car in full Vac to full Boost and from O rpm to Redline, Idle, Mid Range, and WOT.
Are you running with the stock FP? If so surprised you don't lean out up top..
I''m using the stock Fuel Pump, It's a good idea to to upgrade and I'm in the process of doing so. I'm for sure maxing out the Stock Pump.
Old Apr 15, 2008 | 10:28 AM
jpc350z's Avatar
jpc350z
When you swap out the pump to a higher flowing Walbro , make sure you do the drilling mod's to the pump recommended by Phunk or you will see fuel pressure's in the 80' s at idle and difficulty with driving in traffic because the ECU/inj won't like controlling at this high a fuel press. That's what I experienced till I went with a RFS..
Old Apr 15, 2008 | 01:53 PM
davidc81's Avatar
davidc81
thank you everyone for your replies.
after doing a bit more research, i have come to the conclusion that i will be fine running the 3.12 pulley with my current mods and a retune. i think i'll hold off on upgrading though.
nexx made a good point about piece of mind. i definitely dont want to do a half-arsed job upgrading my car and i will upgrade the injectors and fuel pump as well. its better to be safe than sorry in the end!
what size/brand injector and fuel pump would you recommend. is this a hard upgrade to do yourself?
Old Apr 15, 2008 | 01:55 PM
NS_350GT's Avatar
NS_350GT
I wouls still say to upgrade the SS box....
Old Apr 15, 2008 | 02:07 PM
Biochem7's Avatar
Biochem7
Regular
get Deastchwerks injectors and upgrade to UTEC if possible.
Old Apr 15, 2008 | 03:30 PM
davidc81's Avatar
davidc81
what size injectors?
Old Apr 15, 2008 | 03:37 PM
NS_350GT's Avatar
NS_350GT
Go with 550cc at least, they will give you plenty of room o work with 440cc are still alittle to small.
Old Apr 15, 2008 | 05:00 PM
markcearley's Avatar
markcearley
jpc350z. "What is IDC?" Injector Duty Cycle
Old Apr 15, 2008 | 06:17 PM
booger's Avatar
booger
can you tell me what values [ numbers ] you put in in the idle rpm cells ? 10 being no change to the ECU and going down from there for bigger injectors . I had tried any where from 9.8 to 8.4 at the idle rpm range with no luck at getting a stable idle . I also had a OBD to check both long and short term fuel trims .
Old Apr 16, 2008 | 05:53 AM
Biochem7's Avatar
Biochem7
Regular
I have 650cc
Old Apr 16, 2008 | 06:33 AM
fishclub's Avatar
fishclub
My 440 injectors max out at 6k rpm with 3.12 pulley set up (SSV HFC Headers and Exhaust). Can I upgrade to 650cc and just use the stock fuel rail and Walbro only? Also, can the utec scale the 650cc good?
Old Apr 16, 2008 | 09:47 AM
jpc350z's Avatar
jpc350z
Correct. Seems like 80% max is optimum..
Old Apr 16, 2008 | 05:34 PM
chaparro78's Avatar
chaparro78
We have close to the same set up then. Utech and Walbro May 8th
Old Apr 16, 2008 | 07:03 PM
RA11325's Avatar
RA11325
How are you 440cc injectors maxing with the 3.12 pulley? I never had an issue with the 3.12 running stock injectors and I run my car pretty rich.
Old Apr 16, 2008 | 07:09 PM
Hexxum001's Avatar
Hexxum001
Upgrading your injectors and fp is definitely a good idea if going with the 3.12. No, it's not necessary but like Nexx said . . . piece of mind. I'm running 550cc DW's and a Walbro fp.
Old Dec 16, 2008 | 08:27 AM
davidc81's Avatar
davidc81
i snapped my s/c belt so i'm gonna take it to the shop and have the 3.12 pulley put on as well as a few other things. do you think i'll be alright with 440 injectors and new fp with the SS box? should i go with 550 injectors? will the SS box be able to scale the new injectors?
Old Dec 16, 2008 | 08:43 AM
sentry65's Avatar
sentry65
the burninator
if you have the full kit, the stock injectors are probably fine
Old Dec 16, 2008 | 10:49 AM
  #38
350Z400rwhp's Avatar
350Z400rwhp
Originally Posted by Nexx
highly recommend deastchwerk 600cc injectors and walbro 255lhp and retune of the ss box
Do this and go with a 2.87 pulley and maybe upgrade to a utec. I should of listened to Jason and went with the 2.87 as the 3.12 is ho hum.
Old Dec 16, 2008 | 10:55 AM
  #39
Nexx's Avatar
Nexx
it's never too late.
Old Dec 16, 2008 | 11:24 AM
  #40
350Z400rwhp
I'm putting it on over the winter Just waiting till it warms up for the tune.
