Injector size ???
Old Apr 19, 2008 | 09:32 AM
Zume's Avatar
Zume
Default Injector size ???
My car was set up with RC 1000cc injectors. Thinking it would run better with smaller (510cc(?) injectors. Cars making more power then mine have smaller injectors. What gives?
Runs fine except for-sometimes idle cycling, terrible gas milage, very slight hesitation when slow accl for stop, black/gray haze observed from behind car during hard acceleration.
VQ engine, JWT (530 turbos), fuel return stm, cams, rods, pistons, HKS V-pro, F-con eng. manag. w/knock amp, ~ 450 whp, 10 or 14 psi boost.
Old Apr 19, 2008 | 09:33 AM
GTM's Avatar
GTM
Vendor - Former Vendor
RC Injectors aren't the best choice. Go with a Denso brand injector. ~600cc should be fine.
-George
GTM
Old Apr 19, 2008 | 09:43 AM
KarenZ's Avatar
KarenZ
everyone says rc's are no good..
is there any reason as to why...
Old Apr 19, 2008 | 10:06 AM
Jay'Z's Avatar
Jay'Z
Do you have problems with start up? Do you have to hit throttle at start up?
Old Apr 19, 2008 | 10:25 AM
Zume's Avatar
Zume
few start up problems...during cold WX it will tend to die & if hot on hot day will take ~ 5 seconds or so of cranking and some times a little throttle to start. Generally I don't touch the throttle during start.
Old Apr 19, 2008 | 10:27 AM
Jay'Z's Avatar
Jay'Z
I hate my start up.. I have to kill the throttle with my foot!! It drives me ****ing insane..
Old Apr 19, 2008 | 11:40 AM
GTM's Avatar
GTM
My friend is selling a used set of Denso 650cc injectors btw.
/end plug
-George
GTM
Old Apr 19, 2008 | 11:42 AM
captj3's Avatar
captj3
JayZ your start up problem is utec related. That's just how the utec is, because they released it with promises and never followed thru with them.
Old Apr 19, 2008 | 12:20 PM
Zume's Avatar
Zume
Default used Denso injectors
I would be interested in your friends 650cc injectors, with the following two questions- 1) Is it possible that these too are too big? and 2) if I am going to invest the time & expense of changing them out what about Nismo 555 injectors? this is what JWT uses...also, what about install issues. *I plan on doing these myself...what would be*easier*to put back in once the RC's are taken out?
Old Apr 19, 2008 | 12:30 PM
GTM's Avatar
GTM
Well the Denso's are a direct replacement for your OEM injectors, no modification needed at all. They ran on his car with a VPro like a stock car, no start issues, no stalling, You wouldn't know it was modded if it wasn't for the loud supercharger lol.
BUT, Since you have RC injectors your injector harness has been modified, so you would need a new OEM injector harness.
-George
GTM
Old Apr 19, 2008 | 12:47 PM
Zume's Avatar
Zume
Default injc
Any idea on price of OEM injector harness?
How are Denso's better then other's...RC's (Why are RC's getting bad rap?). I am still wondering why I have such big injectors (other than future pwr increases) and why am I having issues...the brand or the size or both???
the way my car is now more power would just lite up the tires more...no point
Old Apr 19, 2008 | 12:52 PM
Jay'Z's Avatar
Jay'Z
Bro.. You may be 100% correct!! I thought the RC high impedence inj was the prob, because i never had this startup bs with 440cc inj.. WTF..
Old Apr 19, 2008 | 12:56 PM
GTM's Avatar
GTM
I have HKS 1000cc injectors, and my car idled like stock. But HKS injectors are made by Denso, which is one of the largest fuel injector (among many other OEM parts) manufacturers, world wide.
Basically, RC injectors are all modified injectors, have a horrible spray pattern, and are often referred to as "garden hose" injectors. The atomization is poor, and the bigger size RC injector you get, the worse the problem.
I would guess and OEM injector harness is sub $100, call your local Nissan dealer, or check with any online vendor.
-George
GTM
Old Apr 19, 2008 | 12:57 PM
GTM's Avatar
GTM
I might also add, that the tuning should be checked, as that could also be making the problem worse, if not part of the problem.
-George
GTM
Old Apr 19, 2008 | 12:59 PM
Jay'Z's Avatar
Jay'Z
-George
GTM
Does HKS make a 750cc inj??
Old Apr 19, 2008 | 01:03 PM
eltness350's Avatar
eltness350
The Untouchable
i dont think so ...get deatchwerks injectors...nothin but great things from them
Old Apr 19, 2008 | 01:04 PM
Jay'Z's Avatar
Jay'Z
Why would utec give me start up issues?? It doesnt make sense to me..
Old Apr 19, 2008 | 01:23 PM
Mike@DW's Avatar
Mike@DW
We have brand new denso connectors with pig tails. Save you some money over buying a harness from nissan.
Mike@deatschwerks.com
Old Apr 19, 2008 | 01:24 PM
App6MT's Avatar
App6MT
Who suggested 1000cc injectors in the first place?
Old Apr 19, 2008 | 04:12 PM
GTM's Avatar
GTM
I believe they make a 720cc injector not sure..... check www.hksusa.com
