Ck eng lite/service engine soon light...ON!
Old Apr 22, 2008 | 06:43 PM
Zume's Avatar
Zume
Default Ck eng lite/service engine soon light...ON!
built mtr, JWT 530 kit, hks v-pro, test pipes...runs very rich...
"service engine soon" light is basically on all the time...is this normal??? The shop that did car says its is...get over it, it can't be helped. I think this is wrong...bad Juu Juu...if car is tuned properly with $$$ v-pro this light should not be on unless there is a problem.
+ I need to get buy gov. emissions ck soon. This will be impossible.
Should I get ECU reflash, HKS redo, Stillen Hi-Flow cats, new injectors, new tune???
Old Apr 22, 2008 | 07:06 PM
westpak's Avatar
westpak
SFZCC
you have to find out what the code is for to get an idea is it should be on or not
Old Apr 22, 2008 | 07:10 PM
frankie945's Avatar
frankie945
what year is your Z 05 and up I bet it is your test pipes throwing the code.But like above see what code it is .
Old Apr 22, 2008 | 07:36 PM
Zume's Avatar
Zume
Default g35 05 at
I think its a rich code...when reset comes back on w/ in 25 miles...
Old Apr 22, 2008 | 07:49 PM
Zume's Avatar
Zume
Default g35 05 at
Rich codes...again and again. This is the car with the 1000cc/min injectors. Should not the V-pro be programmed to understand the set up ???
Old Apr 22, 2008 | 07:56 PM
westpak's Avatar
westpak
SFZCC
if it is rich and yours is an 04 not 04.5 then you should not get the code, I have Fcon with 1000cc injectors and not codes, so it is not the Fcon but the tuning
Old Apr 22, 2008 | 08:13 PM
Zume's Avatar
Zume
Default 2005, G35 cpe at, built/530jwt/14psi/vpro
2nd shop...$40K spent...car still not (tuned) right...this could get depressing...
Old Apr 23, 2008 | 08:30 AM
GTM's Avatar
GTM
Vendor - Former Vendor
In most cases, running a standalone EMS will trigger a CEL since the factory computer is not seeing any responses to the adjustments it is trying to make to fuel and timing, since it is not in control. It thinks something is wrong and throws a code.
Our GTM ECU Flash removes the codes caused by running a standalone EMS but leaves the others intact incase there is a real problem, you still get a CEL.
-George
GTM
Old Apr 23, 2008 | 05:26 PM
j.arnaldo's Avatar
j.arnaldo
My mother had a '97 Escort whose "Check Engine Soon" light came on early after she bought it new. We NEVER took it for a check up; it NEVER broke down; it NEVER developed a miss; it NEVER gave us ANY type of trouble! I was told by a DIYourselfer friend that it's a gimmick by auto manufacturers to
charge fees for "computer diagnostics", & other "maintenance checks"...Bogus
stuff, guys!!! If the car feels O.K., DON'T waste a penny at the stealership!!!
Old Apr 23, 2008 | 08:16 PM
overZealous1's Avatar
overZealous1
makes it impossible to make it past emissions though for guys that have to do it if a code is showing. go buy a cheap code reader and figure the codes! many people on this site can tell you what it is and how to fix it after that.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
