Quick questions
Old Apr 22, 2008 | 11:33 PM
wannabuy350z's Avatar
wannabuy350z
Default Quick questions
I finished my installed on the JWT TT 530, but I forgot to change my plugs, and I am getting a little lazy to look into the engine bay. will stock plugs hold up ok?
Thanks
Old Apr 22, 2008 | 11:36 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Thanks
Go with one step colder iridium ASAP. Don't risk your engine for such a small detail....
Old Apr 22, 2008 | 11:42 PM
wannabuy350z
I will be going NGK one step colder, just wondering how bad it is. I am not experiencing any knock.
Old Apr 23, 2008 | 03:20 AM
taurran's Avatar
taurran
It depends on the tune and the boost levels being run. If you're absolutely postive it's not knocking while under heavy load and while heat soaked, then you probably don't have much to worry about. If you push your car hard on the track or for extended periods, they're not a bad idea for a little cheap added protection.
Old Apr 23, 2008 | 07:06 AM
wannabuy350z
I just go to work and back, light to light pulls, and maybe highway when I am on it.
Old Apr 23, 2008 | 07:59 AM
350Z400rwhp's Avatar
350Z400rwhp
Just replace them it's cheap insurance.
Old Apr 23, 2008 | 09:33 AM
wannabuy350z
I have spoken to JWT and they said they recommend it. plus my plugs are new, less than 10K on them. i will be on the stock JWT SS box tune, so pig rich.
Old Apr 23, 2008 | 06:07 PM
j.arnaldo's Avatar
j.arnaldo
With electronic ignitions, plugs go a l-o-n-g way. Depending, also, on the quality of the gas, they should produce a fine spark for thousands of miles.
If you know an auto electricity mechanic or, even better, an automotive en-
gineer, ask about this. Iridium IS the plug to go with, IF you actually need them.
Old Apr 23, 2008 | 06:43 PM
SC 350Z's Avatar
SC 350Z
any one have the part number on these step colder plugs?
Old Apr 23, 2008 | 10:07 PM
wannabuy350z
^Nissan 22401-5M016 (NGK)
Old Apr 23, 2008 | 10:32 PM
SC 350Z's Avatar
SC 350Z
^ gotcha thanks man
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
