Vortech Revup & Non Revup
Old Apr 26, 2008 | 11:11 AM
Dreamsmith's Avatar
Dreamsmith
Default Vortech Revup & Non Revup
i have a 5AT g35 running stock vortech revup s/c setup
i have read about the pulley size difference and the cog pulley...
is there a difference in the vortech unit itself?
and do i need to change anything to make the setup better?
Old Apr 26, 2008 | 11:48 AM
r0csfinest's Avatar
r0csfinest
I thought 5ATs only ran the non-rev up?
Old Apr 26, 2008 | 11:54 AM
Dreamsmith's Avatar
Dreamsmith
yes 5AT is non-revup... but am running a revup kit
Old Apr 26, 2008 | 11:57 AM
05Z33's Avatar
05Z33
The mounting bracket is different from non revup to revup.
Old Apr 26, 2008 | 12:11 PM
Dreamsmith's Avatar
Dreamsmith
hmm....
u sure?
u got me confused...
how can i make sure which kit am running?
i know am running 3.12 pulley...
Old Apr 26, 2008 | 12:33 PM
05Z33's Avatar
05Z33
If what you have is a revup kit and you plan to mount it on a non revup motor you may have problems installing the mounting bracket onto your car.
Old Apr 26, 2008 | 12:49 PM
Dreamsmith's Avatar
Dreamsmith
the kit i bought is second hand...
so as i remember the mech told me its revup kit but it will fit, and i have been using it for a while now.
i bought it with 3.12 pulley on it, and i just checked the cog pulley its 34 tooth
Old Apr 26, 2008 | 12:55 PM
Dreamsmith's Avatar
Dreamsmith
this is a picture of the plate
Old Apr 26, 2008 | 12:59 PM
05Z33's Avatar
05Z33
So you have it up and running then? If that's the case never mind what I said. check the cog pulley on the blower itself and see if it's a 28 tooth cog, if not then change it to the 28 and that should increase your boost.
05Z33's Avatar
05Z33
That's not a revup kit.
Old Apr 26, 2008 | 01:05 PM
booger's Avatar
booger
+1
You have a non rev-up . Its has a 28 tooth cog blower pulley , a 32 tooth jackshaft cog , and a 3.33 serp pulley , or maybe a 3.12 serp pulley .
If you having trouble making over 7psi or better . Try buying a NAPA or Gates belt the same size as the stock belt . Make sure it tight enough .
Old Apr 26, 2008 | 01:08 PM
Dreamsmith's Avatar
Dreamsmith
hmm...
so maybe the previous owner ordered it with 34 tooth cog pulley ?! :S
so i have got 3.12 pulley, 34 cog pulley, dunno about the other cog pulley... i have headers, test pipes, borla catback... and am making ~8psi is that correct?
if it is, what do you suggest i should do to increase the boost ?
Old Apr 26, 2008 | 02:22 PM
booger's Avatar
booger
hmm...
If you indeed have the 34tooth cog and the 3.12 , you should be making 10psi or better . You could have a slipping belt , or a boost leak .
Old Apr 26, 2008 | 02:33 PM
Dreamsmith's Avatar
Dreamsmith
in addition to all the breathing mods, i have a built engine, and ported and polished heads..
i think ~8psi is correct.. dont you agree?
Old Apr 27, 2008 | 10:34 AM
str8dum1's Avatar
str8dum1
no, that boost is to low.
Old Apr 27, 2008 | 12:06 PM
Dreamsmith's Avatar
Dreamsmith
hmm.... how can i check for boost leaks?
Old Aug 8, 2008 | 06:41 PM
stealthz's Avatar
stealthz
it could still be a rev-up kit as long as the bracket was changed to a non-rev-up bracket... check the ss -box for two sets of wires not spliced... I believe the rev-up ss-box has 4 extra wires for the exhaust cams timing or something....
Old Aug 8, 2008 | 10:59 PM
350Z400rwhp's Avatar
350Z400rwhp
I made a DIY on a home made pressure test kit for the Vortech https://my350z.com/forum/engine-driv...-test-kit.html. Unless you have lower compression pistons I would think you would be more like 9 psi. You do have a lot of breathing mods though so 8 might be right. If I were you I would just go to a 2.78 pulley so long as you have bigger then stock injectors and a upgraded fuel pump. You should also do at least a utec if you go this route.
Old Aug 29, 2008 | 12:33 AM
stealthz's Avatar
stealthz
hmm...
I don't think you have a problem with your kit at all... If it is a rev up kit than chances are your running a 34 tooth upper cog and a 32 tooth lower cog and if you are running a 3.12 serp pulley than your running the stock set-up for a rev-up on a non-rev up bracket which means your running about stock boost which your dead on.... and if you are running the 34/32 tooth cogs you could actually drop down to the 2.87 serp. pulley and be safe with a tune.... basically just check out your other lower cog pulley if it's 32 tooth than your running the s.c. stock and if it's the 28 than you have an issue....
I just recently converted my kit as well and I'm running the 34 tooth upper and the 32 tooth lower and I downsized the serp. pulley to 2.87 which is safe with a tune... it would be like running the 32/28 cog with a 3.12 pulley....
and I do think the 34/32 cog w/ 3.12 is a better stock set-up on the vortech than the 32/28 cog w/ 3.33 pulley
So basically your car is running right!
Old Aug 29, 2008 | 05:23 PM
SC 350Z's Avatar
SC 350Z
thats a vq35de nonrevup engine and a nonrevup vortech supercharger bracket the cam cover sticking threw the bracket is totally differetn from revup to nonrevup the nonrevup bracket would never fit on a revup engine
