plenum,stall?!
Old Apr 26, 2008 | 09:32 PM
aguita's Avatar
aguita
Default plenum,stall?!
i just installed a plenum spacer and I noticed that sometimes when the car is warm when i start the engine the rpm's sometimes go to 300 or lower like the car wants to shut off..is this the symptom of a air leak?? after that the car idle smoothly...should i perform a reset? or something like that..also what can we use to clean the TB and for the MAF i have used CRC maf cleaner..thanks in advance.
Old Apr 26, 2008 | 10:01 PM
JAM3Z's Avatar
JAM3Z
Phenom
Mine did this too, but I put some little rubber gaskets under the plenum bolts and its fine now.
Old Apr 26, 2008 | 10:20 PM
Mr_pharmD's Avatar
Mr_pharmD
u have a leak.
Old Apr 27, 2008 | 10:06 AM
aguita's Avatar
aguita
nice...I put the washers that came with teh bolt...Jamez you mean the bolts 6 on top of the plenum or the one around the plenum? also what kind of rubber gasket do you mean?what can I use instead?
sherm
Apr 11, 2020 05:21 PM
allmycarsdie
May 13, 2016 04:38 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
