More upgrades = More problems....Car wont rev past 1k RPM!!
Old Apr 30, 2008 | 06:38 PM
Zivman's Avatar
Zivman
Originally Posted by Z_boy912
you mean the fuel pump that comes with the aps fuel system is 255? i tried searching aps website with no luck...
might also be a bad vaccum feed, need to check that too!!
what fuel pressure i should adjust the fpr to with the stock block and 600cc injectors (aps fuel system)?
yes, the aps pump is a 255
You can't adjust the fpr. It is set and rises 1:1 with boost. at idle you should see around 52-56 psi if I remember correctly.
Old Apr 30, 2008 | 08:08 PM
jining's Avatar
jining
I believe OEM spec is 51psi with the vaccum line off at idle.. what do you mean you cant adjust the FPR? Or are you talking about the one that comes with the APS fuel system
Old Apr 30, 2008 | 08:42 PM
Zivman's Avatar
Zivman
you can't adjust the fpr. it is non adjustable....
Old Apr 30, 2008 | 08:54 PM
jining's Avatar
jining
So the aps fpr isn't adjustable your saying. Ok I didn't know that.
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
AbyteZero
Sep 22, 2015 09:17 AM
Calinismo350z
Sep 14, 2015 04:04 PM
ZpikeZ
Oct 21, 2005 04:25 AM
