benefits of solid motor mounts?
what kind of cams are you running that you needed to jack up the idle to 1300rpms btw?
I'm just running JWT so 850 would have been fine.
I run 1300 because it kills off the vortech rattle and makes my ATS dual clutch more forgiving. I could get by with 1000 rpms, but I like 1300 a little better. Actually I'd probably like to lower it to 1200 next time I go to GTM
Originally Posted by sentry65
the cams aren't really the reason I went up to 1300
Originally Posted by booger
at 1200 to 1300 rpm , the motor has got to sound likes it reving pretty dam high just sitting at a light . Have people asked you.....whats wrong with your car ?
it just sounds a little louder and more aggressive
sounds somewhere around a billion times better than the 'broken rocks in a can' sound the vortech and my clutch will make if the idle is anything less than 900 rpms. Going more than 1000 rpms actually makes the vortech sound quieter and smoother at idle
stock Z's don't even sound like they're turned on to me when they idle
The solid motor mounts are... Well lets just say that you know a car that has them when you drive/ride in it. I built my car for track purposes so the increased vibration is acceptable to me.
It seems there are people on both sides of this fence but I would agree with those who would probably not recommend them for a daily driver. On the plus side, now that my car is like a giant vibrator, maybe I will be able to pick up more girls in it
I agree with sentry.. I didnt feel more vibration.. It did feel like better shifts etc..
Maybe my Z is too loud to know a difference..
I loved my solid mounts I made for my Z. I think that they added very little vibration and the amont they did was completely acceptable. I also feel that throttle response is more crisp.
i think most of the guys that have the solid mounts got them from me when i was making them, so kinda interesting to see the different opinions.
i built the first set for my car and i really didn't even notice a difference when i put them in. most other cars i built them for were V-8's, and because of the firing order, you really feel it then!! but to me, that is kinda bad azz to see the car shaking at idle, haha. little intimidating really. for f/i Z/G's, the plumbing is so tight in the engine bay that keeping the motor solid in relationship to all the other parts gives a touch more protection of the hoses coming loose. i personally made the mounts shorter so you can fit a taller plenum spacer and get a lower cg. i am able to run a 5/8" spacer and still have about 1/8" off the stock strut bar with no chance of it ever hitting.
for a track car, yes, all your throttle, decel, and clutch inputs are now solid rotationally. personally, i would not have it any other way for my own car, even if it only sees mostly street driving. i am VERY much in tune with my car and like to feel every single last thing it is doing.
imo, the benefits far outway the slight negative of a hardly noticeable (atleast to some) gain in vibration. i would be rocking a caddy if i wanted plush, hahhaa.
At idle, I dont notice much if any difference. But under load there is more vibration. And like I said, I am cool with that. I threw comfort out the window a long time ago with my car - I have no stereo, gutted cf hatch, race buckets. Civility is not a priority
I had solid mounts and a 6 puck clutch in my old civic. I loved how much that car beat me up.
I'd do it to my Z just because I rarely drive it and dont mind being rattled to hell, however if I drove the car more often.... NO THANKS!
350z, advantages, annoying, benefit, benefits, benifits, cars, differential, engine, firm, motor, motormounts, mount, mounts, solid
