Leakdown test on built engine
Old May 6, 2008 | 04:07 AM
Madelinot's Avatar
Madelinot
Default Leakdown test on built engine
Hi all,
I have a used and build engine with Arias 8.6:1 pistons and Eagle forged rods. It's been sitting in my garage for a little while, almost two years in fact. I soon want to drop it in and did a leakdown test on it. Four cylinders turned out with low leakage, two with moderate leakage. The leaks are always through the intake valve it seems. Should I be concerned? Does the fact that the engine has been sitting for several months affect the readings? Should I still consider to drop it in?
Thanks for any insights,
Old May 6, 2008 | 04:58 AM
go-fast's Avatar
go-fast
the valves might be open during test,could also be going past the rings.as motors sit oil drains back and provides extra clearance.plus your testing a cold motor,not a very efficient test.you can put a squirt of oil in the spark plug hole and see if your readings improve.is the intake on the motor?
Old May 6, 2008 | 05:49 AM
Madelinot's Avatar
Madelinot
Thanks! I tried to set up the pistons so that they're just a few degrees before TDC. All valves should be closed. I'll try to add a bit of oil in the cylinders to see if that make a difference. The intake is NOT on the car and I realize that a cold engine will leak more than a warm engine, that makes sense.
Thanks!
Old May 6, 2008 | 08:04 AM
QuadCam's Avatar
QuadCam
Thanks!
TDC of the compression stroke or the TDC of the exhaust stroke. if you are on the 4th stroke of the cycle, the valves won't be closed! you'll want to make sure that you are on the 2nd stroke (compression) of the cycle for each cylinder.
Old May 6, 2008 | 08:46 AM
westpak's Avatar
westpak
SFZCC
easiest way to tell is to stick a long rod down the spark plug hole and turn the engine until the rod reaches its highest point then do the leak down on that cylinder
Old May 6, 2008 | 09:06 AM
MardiGrasMax's Avatar
MardiGrasMax
could have a little crud build up from sitting with the intake valves open on the valve/seats that are holding the valves open. The question is waht the motor in goot shape before yu took it out?
Old May 6, 2008 | 10:41 AM
go-fast's Avatar
go-fast
that doesnt account for overlap
Old May 6, 2008 | 10:43 AM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
stock valve springs or aftermarket?
Old May 6, 2008 | 10:52 AM
westpak's Avatar
westpak
SFZCC
no but it helps eliminate some of the guesswork
Old May 6, 2008 | 10:56 AM
go-fast's Avatar
go-fast
i like to pull a valve cover an put fingers on the buckets,the first couple you may have to fiddle,but after that you can feel where the sweet spot is.
Old May 6, 2008 | 11:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I would not expect a perfect seal from an engine sitting for 2 years. What are the actual leakdown %'s you are seeing?
Old May 6, 2008 | 02:09 PM
QuadCam's Avatar
QuadCam
you won't have any overlap if you are at the top of the compression stroke!
Old May 6, 2008 | 02:14 PM
tig488's Avatar
tig488
also depends on which hole you put the rod in, but doesnt it always.
Old May 6, 2008 | 03:39 PM
go-fast's Avatar
go-fast
+1
Old May 6, 2008 | 05:46 PM
gothchick's Avatar
gothchick
So true, so true. Lol~ :-)
Old May 6, 2008 | 07:23 PM
Madelinot's Avatar
Madelinot
Stock heads i think. This is a used built block that I purchased from a member on here several months ago (5000 miles on the rebuilt). He said it was running strong. I will redo the tests this weekend to ensure that I was at the end of the compression stroke, not on the exhaust stroke. But even TDC after the exhaust stroke, the intake valves should be closed, right?
Thanks so far. I'll post my exact test results this weekend.
Old May 7, 2008 | 12:31 PM
350 Rookie's Avatar
350 Rookie
just pull the valve covers already. look at the cam lobes to make sure if they are open or closed. its so much easier than trying to figure out your stroke and if you are exactly TDC.
Old May 7, 2008 | 04:52 PM
QuadCam's Avatar
QuadCam
just pull the intake manifold.....you can see right down the runners. watch the valve openings/closings. it is easy to figure out.
also, a tool like this one is great to have for finding TDC......
TDC Indicator for Deep Spark Plug Wells 10.75" Long
Accuracy is key for maximum cam and engine performance. Here are a couple ways to assure the number 1 piston is at true Top Dead Center. Installs as easily as a spark plug and is available in 6" standard length (46238) and 10.75" extended length (46237) with a 14mm threads. . Just remove the spark plug, screw in the gauge and rotate the engine observing the 1/8" graduation marks on the sliding shaft. Note the top of the piston stroke. Can be used with a dial indicator. Made in USA. Limited lifetime manufacturer's warranty
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
