GReddy E ultimate with SC?
Old May 19, 2008 | 11:24 AM
GTM's Avatar
GTM
Vendor - Former Vendor
How did you pay $1,700 USD for a E-Manage Ultimate? Doesn't it retail for like $599?
Any the reason the e-Manage Ultimate is inadequate is because it is a piggy-back style computer, all piggy back computers are inadequate IMO.
Utec takes full control of timing once in boost, so it is somewhat like a standalone for timing. Resolution sucks, but hey its cheap and great for 10PSI or less.
You guys should really invest in a good standalone, it will be the best mod in so many ways.
Old May 19, 2008 | 11:28 AM
robbycolli's Avatar
robbycolli
Do you consider the Haltech a stand-alone?
Old May 19, 2008 | 11:31 AM
SIR_pierre's Avatar
SIR_pierre
sweden.everything cost the doubble here.. and that was including the harness.
i didnt have any big plans for the SC...max 100hk
Old May 19, 2008 | 11:37 AM
athenG's Avatar
athenG
Originally Posted by robbycolli
I don't know. How can I tell? Would the tuner not know this?
Would changing to a Map Sensor fix the problems I am describing? Thanks,
How wuch is a map sensor and how hard to install? Who makes them?
Ask your tuner if you are using one.
Here's more info .. http://g35driver.com/forums/showthread.php?t=190565
Old May 19, 2008 | 02:23 PM
nomyth46's Avatar
nomyth46
i got $17k in my built TT setup.............hey robby, i thought you were going single turbo with you build
Old May 19, 2008 | 02:29 PM
GTM's Avatar
GTM
Yes it is a standalone, it has full control over timing and fuel, and plenty of resolution to do so.
Just because a EMS works in parallel with the OEM ECU to maintain creature comforts does not make it a piggy back.
My friend is running a MoTeC and still left the OEM ECU in their for the creature comforts, although he could take it out if he wanted too, just would create himself a bunch of work.
-George
Old May 19, 2008 | 02:34 PM
nomyth46's Avatar
nomyth46
the map sensor plugs into a vac. line and its basically if i'm not mistaken a boost refrence for the Ems.........but anywho ben at national should be able to tell you...........i had a EU and it didn't work for me at all i sold it and i got a Utec
Old May 20, 2008 | 07:18 AM
robbycolli's Avatar
robbycolli
Thanks alot for the help guys. Will I still need to Map sensor with the Haltech?
Old May 20, 2008 | 07:19 AM
robbycolli's Avatar
robbycolli
If I will need a map sensor for wither setup, I may try to just install the map sensor first and wait on the Haltech.
Thought about a single turbo for about a day but had too much invested in the SC setup to be willing to make the change.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
z33z_nutz
Sep 23, 2015 07:22 PM
