Small Detonations
Old Jun 10, 2008 | 01:00 PM
Rmrichards1385's Avatar
Rmrichards1385
Originally Posted by SlideFox
Edit: If you can budget in a Nismo T-stat, I would do that before we start seeing 115+, JMO
Whats the nismo t-stat going do for me? That just a way to monitor the heat?
Old Jun 10, 2008 | 01:19 PM
SlideFox's Avatar
SlideFox
http://www.intensepower.com/nilowtethkit.html
It opens the thermostat @ 154 degrees rather than @ 170 degrees OEM. Allowing your motor to run a little bit cooler.
Old Jun 10, 2008 | 01:44 PM
Rmrichards1385
nice man, so here's another q, my mechanic from Import Auto just said he talked to Turbonetics, the guy said he has a g35 w the same issue, recommended aem ems...a stand alone vs the utec....which one is better?!? I mean of course the aem is huge bc it contols the car alone, but is there really more you can do over just a utec?
Old Jun 10, 2008 | 02:13 PM
SlideFox's Avatar
SlideFox
STAY AWAY FROM THE AEM!!! Standalone is the best way to go! Obviously it's gonna cost you a bunch more then a UTEC, but the UTEC will handle what you need it to do. If you want to spend the bucks on a standalone... I would go with HKS F-Con V-Pro, ProEFI Pro48, or Haltech. There really isn't a "true" standalone for the Z. All these computers still use the OEM computer to control the dashboards, A/C controls, etc...
Since your AZ, I would look @ the ProEFI if you want to go standalone. They are based in AZ, and you would have great support should you ever need help with the computer.
Old Jun 10, 2008 | 02:36 PM
Rmrichards1385
Utec With Dyno And Tune For About 1600 Out The Door Sound Like A Good Deal?
Old Jun 10, 2008 | 02:40 PM
SlideFox's Avatar
SlideFox
Does that include the MAP selector switch? That's a pretty good deal if it does.
Old Jun 10, 2008 | 02:54 PM
Rmrichards1385
Smile
pretty sure, like depending on if it's hot outside you can switch the different maps, I'm pretty sure that was including bc we were talking about that and he gave me the total price after everything. Im excited man, Im really looking forward to this bein done!
Old Jun 10, 2008 | 04:01 PM
350Z400rwhp's Avatar
350Z400rwhp
You are really going to like the utec. I love mine, my car starts and runs like stock and drives without any hiccups.
Old Jun 10, 2008 | 06:39 PM
captj3's Avatar
captj3
Originally Posted by athenG
Why do you have to turn up the boost with meth? I'm using it and still running the same boost... You can still use it as an added safety for your car. Meth is very beneficial if you live in a state that goes above 90F all the time. How can you say lowering your AIT, EGT increase octane level is not a good thing. You only raise your boost or add more timing if you want more power because Meth allows you too.
Yes tthe advantages of having meth are as you say. But most of the time people will take advantage ofhaving it and turn up the boost if they can. You can understand it's just 1 or 2 lbs and so on in the heat of the moment.
Old Jun 10, 2008 | 06:51 PM
captj3's Avatar
captj3
Originally Posted by 350Z400rwhp
Relax dude, I not trying to be a salesperson. If you read my first response I said the utec was the cure. If you read my second response I said the meth injection would be a band aide fix. People need to start reading before the call others out.
Relax dude, trust me if I were calling you out I would have used your name. Yes I can read and comprehend as well. Don't take everything to heart that's usually the sign of a guilty concision.
Old Jun 10, 2008 | 07:27 PM
Rmrichards1385
how often do you need to refill the methanol/water mix? The spray only goes into effect up full throttle right? Just wanna make sure if I did add meth injection, I'm not gonna b drivin around wasting it all day.
Old Jun 10, 2008 | 07:33 PM
350Z400rwhp
one gallon every 3 or 4 tanks of gas, I use my washer fluid tank for a reservoir though and its about a gallon.
Old Jun 10, 2008 | 07:57 PM
Rmrichards1385
ya but is it spraying while you are just cruising? Or only when you get on it?
Old Jun 10, 2008 | 08:27 PM
350Z400rwhp
only starts spraying at 4lbs and works its way to 100% at 10lbs Its a progressive meth kit.
Old Jun 11, 2008 | 04:48 AM
jpc350z's Avatar
jpc350z
What's the big benefit here. Opening a little sooner? Once temp reaches 170 which would probably be 3-4 minutes after 154, it remains open no? Temp's not going below 170 during driving?
Fixxxercask
Nov 9, 2015 11:10 AM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
