483whp and 643Nm at 1.1 Bar boost on APS TT
Old Jun 12, 2008 | 11:52 AM
noer's Avatar
noer
Default 483whp and 643Nm at 1.1 Bar boost on APS TT
Hi Guys,
Check out my Dyno below. The power is awesome considering it is a built motor with Stock APS 440cc injectors and Unichip. The tuner says everything seems fine in terms of AFR etc. But I think I am pushing it 2 much on my car because I should only be running 440whp with those injectors.
Been running about 4000km with that power... should i rather turn down the boost.. what are your guys opinion?
Old Jun 12, 2008 | 03:39 PM
al_v's Avatar
al_v
I did 450rwhp on a dynojet , ( stock aps TT , runing 10 lb , built engine with 9.2:1 of CR) and the fuel injectors were max out.
What is your CR ????
Do you have the stock aps fuel return system???
What kind of dyno???
You can´t run 1.1 bar with 440cc injectors and the stock aps fuel return , unless you reduce the boost from 4500 rpm to around 11 lb in red line.
Old Jun 12, 2008 | 04:47 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Originally Posted by noer
Hi Guys,
Change out your injector ASAP!!! Built engines also blow up if you don't take care of these little things......
Old Jun 12, 2008 | 05:01 PM
Madelinot's Avatar
Madelinot
My APS injectors are also maxed out at 9psi. I did 449whp three years ago with it.
Good luck.
Old Jun 13, 2008 | 01:38 PM
weslutes's Avatar
weslutes
My injectors maxed out at 400whp.
I believe it is because I installed the CJM s1 fuel return though.
Old Jun 15, 2008 | 11:56 AM
GTM's Avatar
GTM
Vendor - Former Vendor
That is why, because the APS regulator runs these injector at a much higher FP to call them "440cc", they are probably really only 380's or so.
I run my HKS 1000cc injectors at 2.5BAR, 2.5-3 is optimal for FP.
OP, upgrade your injectors, and keep in mind if you stay with the APS FPR the injectors will be putting out more fuel than stated.
-George
HoBrahYouStink
Jun 24, 2016 10:58 PM
codek
Sep 28, 2015 03:03 AM
