I need turbo AF help NOW (Race sat & sun)
Old Jun 19, 2008 | 05:24 PM
Boozt's Avatar
Boozt
Default I need turbo AF help NOW (Race sat & sun)
I run the STS rear mount 8psi...Car is suddenly running lean at idle and cruising speeds..system uses UTEC. AF ratios under full boost are 10's to 11:1 (happy with that) but highway cruise in 6th at 70 mph is 17 + :1 and idle is 16 to 17:1. I have a two day race this weekend I can't miss or I will loose first place standings for the season. I NEED HELP NOW. Thanks- Jim
Old Jun 19, 2008 | 05:31 PM
frankie945's Avatar
frankie945
add fuel, adjust your 0% column only.
Old Jun 19, 2008 | 06:13 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
you may also want to look into what caused the sudden change to ensure it doesn't happen again or get worse during your race.
Old Jun 19, 2008 | 06:32 PM
SpoilsofWar's Avatar
SpoilsofWar
Any chance its just your wideband being stupid? Maybe recalibrate if thats an option on your particular model.
Old Jun 19, 2008 | 06:35 PM
athenG's Avatar
athenG
Goosegoose had the same problem way back then were he lean out (around 18-21 A/F) at 0 column but fine under boost. I think cleaning his Throttle body fixed it. See if reseting the ECU help too.
PM Goosegoose and here is his thread...
https://my350z.com/forum/tuning/313435-utec-tuned-sts-leaning-out-to-21-afr-on-low-map.html
Old Jun 20, 2008 | 06:25 AM
Boozt's Avatar
Boozt
https://my350z.com/forum/showthread.php?t=313435
Thanks AthenG...I'll clean out the throttle body today and see if it helps.
I'll also check the zero column but my car doing exactly what goosegoose car did. Thanks again. -Jim
Old Jun 20, 2008 | 07:53 AM
Hoooper's Avatar
Hoooper
make sure you dont move the throttle plate by hand unless its unplugged!
Rev_Night
Nov 7, 2020 06:00 PM
