Borla TD
Old Jun 22, 2008 | 05:48 PM
Z DreamZ's Avatar
Z DreamZ
Default Borla TD
I've installed a set of Borla TD Exhaust. If I want to go twin turbo setup in the future, would Borla TD be recommended for turbo.... or other better suggestions?
Old Jun 22, 2008 | 06:56 PM
05Z33's Avatar
05Z33
I would get at least 2.5 inch TD for TT.
Old Jun 23, 2008 | 04:22 AM
The Captain's Avatar
The Captain
Borla is 2.5... did you mean 3"? That's usually what I see for FI.
Old Jun 23, 2008 | 05:01 AM
05Z33's Avatar
05Z33
Sorry but you're wrong, it's 2.25. I have personally measured it.
Old Jun 23, 2008 | 05:21 AM
The Captain
Sorry, you're right. >_< I should have known this considering I ordered the 2.25" Magnaflow X to put on mine.
Old Jun 23, 2008 | 06:48 AM
Z DreamZ's Avatar
Z DreamZ
Default Hola
Thanks guys! So what do you think? So even if I hook up the highly anticipated GReddy Twin Turbo for VQ35HR seen at SEMA 2007, will the Borla TD be sufficient for the TT setup? What do I have to lose/gain?
Thank you
can't wait for an HKS F-con!
Old Jun 23, 2008 | 10:35 AM
05Z33's Avatar
05Z33
Thank you
It will work for now, but I would seriously look into a bigger exhaust in the mean time. The borla will be restrictive, so you will lose top end power and put more stress on the motor.
Old Jun 23, 2008 | 10:37 AM
Nexx's Avatar
Nexx
+1, you could get away with it in low boost setup though.
Old Jun 23, 2008 | 04:38 PM
superchargedg's Avatar
superchargedg
Damn Noobs
No you cant..........well my cats did do a burn out into my borla so i have a ton of soot into that single muffler which killed my power.I have a 5at auto and i could only get 351rwhp and 396rwt out of my borla which of course had a ton of cat convertor material in it.I had my stock cats basically implode due to the greddy twins and that crap is still in my exhaust even after i pulled the rear section off and dumped a ton of crap onto the floor.
I cant wait to get a 2.75" exhaust and retune it.
Old Jun 23, 2008 | 05:07 PM
05Z33's Avatar
05Z33
Wow that sucks. For the OP if you're keeping the Borla get test pipes.
Old Jun 23, 2008 | 07:04 PM
thawk408's Avatar
thawk408
I rocked borla on the stock block and still put down 425rwhp on sharif's dyno. Its not ideal, but it will work fine. Just dont run cats and you wont have a problem with restriction.
Old Jun 23, 2008 | 08:23 PM
phunk's Avatar
phunk
CJ Motorsports
i ran borla to 573rwhp at 14psi boost with test pipes, no issues. i upgraded to dual 3" with intentions on raising the boost a bit.
i would say that with test pipes the borla is more than enough for all the power you are gonna make on a stock block
Old Sep 16, 2008 | 10:45 AM
Fluid1's Avatar
Fluid1
*Arise, dead thread!*
Phunk, what is your turbo setup?
JjL
East Canada
Jun 12, 2019 03:04 AM
jsunly
Sep 19, 2015 01:22 PM
maserom
Jun 24, 2003 01:20 PM
