tn installation question. see pics
Old Jun 29, 2008 | 12:44 PM
gen05's Avatar
gen05
Default tn installation question. see pics
hi guys. im currently putting my kit together. having a problem right now. i installed the turb housing which one bolt goes on the ac compressor. and i started putting everyother pipes together as the instruction stated. but now time comes to turbo. i found that the high side of ac is hitting. i realized i dont have they called turbosupport bracket. could this be the problem? i dont see a picture in the instruction how they look like. anyone can show me a pics. heres what im talking about. thanks
http://s297.photobucket.com/albums/m...t=IMG_1335.jpg
Old Jun 29, 2008 | 01:56 PM
JS04's Avatar
JS04
Mine did the samething. You can try bending that line out of the way but it may not work. Even with all the bending I did it still was in the way just slighthly. I just disconnected that ac line and I'm going to have a custom one made.
Old Jun 29, 2008 | 02:04 PM
gen05's Avatar
gen05
yea thats what im thinking. i might just remove the lines.
frankie945's Avatar
frankie945
I used a small crowbar to bend it all the way till it touches the water line. real easy to do.
Old Jun 29, 2008 | 02:07 PM
gen05's Avatar
gen05
i tried doing that. but even with bend. when turbo sits in. it will hit against the turbo.
Old Jun 29, 2008 | 02:13 PM
frankie945's Avatar
frankie945
mine is close. when I installed the turbo I had to **** it to the side to get it to fall into place because its so tight. you'll get it don't give up.
Old Jun 29, 2008 | 02:19 PM
frankie945's Avatar
frankie945
heres a pic of mine if you can see way down there
[IMG][/IMG]
Old Jun 29, 2008 | 02:40 PM
gen05's Avatar
gen05
i will try again. thanks. frankie
Old Jun 29, 2008 | 02:46 PM
carfi179's Avatar
carfi179
+1 on using a crowbar, its ok if its touching as long as you double/triple layer the AC line with a heat wrap.
Old Jun 29, 2008 | 03:55 PM
MDeezy's Avatar
MDeezy
becareful, the lines are a little stronger than you think, but still dont HULK it out of the way... would really suck to break that line.
Old Jun 29, 2008 | 04:03 PM
gen05's Avatar
gen05
another question guys. is there a gasket between the downpipe and the turbo? i got the kit used and it didnt come with it. i was just wondering if there is suppose to be one. and is there suppose to be 2 gaskets by the wastegate? thanks
Old Jun 29, 2008 | 04:04 PM
pmohr's Avatar
pmohr
:sprint: (even though that doesn't work here...bah)
They are strong as hell, it will take a fair amount of muscle to bend them. While you're doing it you're going to be thinking to yourself '****, I'm gonna break the hell out of this line'.
Just bend it over as far as possible, you should have some clearance with the turbo. Not a great amount by any means, but enough.
Old Jun 29, 2008 | 04:07 PM
pmohr's Avatar
pmohr
Up-pipe has the metal 4-bolt, the downpipe uses copper RTV as a 'gasket' of sorts.
Don't apply too much, the last thing you want is some RTV on the exhaust wheel...
BTW, installation instructions available here: http://www.turboneticsinc.com/downlo...50Z_manual.pdf
Also, so far as I've heard TN stopped including the up-pipe support bracket with the kits.
There should also be 2 wastegate gaskets, IIRC.
Old Jun 29, 2008 | 04:09 PM
MDeezy's Avatar
MDeezy
it does take a lot of force. shamefully to say, my motor fell off the hoist this weekend (only 1/2 a ft drop) and the A/C was dangling and it bent it a little bit, I thought it would have broken the line cause it fell right on it. these motors are strong
Old Jun 29, 2008 | 04:11 PM
pmohr's Avatar
pmohr
When did you get a Z/G? Bandwagon traitor.
Old Jun 29, 2008 | 04:13 PM
MDeezy's Avatar
MDeezy
I've been here for a while. Was hidding in the computer/ off topic lounge, but I have this affinity for boost that I cant help. Plus doing research
what are you doing here?
Old Jun 29, 2008 | 04:15 PM
pmohr's Avatar
pmohr
Check out my SN on these boards, that should speak for itself. I like to help those doing research.
So, you know who you should have install your FI...a fellow org member :wall:
Old Jun 29, 2008 | 04:17 PM
MDeezy's Avatar
MDeezy
Lol... yea I've seen your title and glad you on here too.
I'm installing my FI kit, and feed piping is almost done, just a couple more measurements. Wiring for my tuning device is almost done
Old Jun 29, 2008 | 04:18 PM
pmohr's Avatar
pmohr
TN ST? What type of EMS?
We should probably take this to PM, we're whoring up his thread.
Old Jun 29, 2008 | 04:22 PM
MDeezy's Avatar
MDeezy
yea we kinda are
I'm still rockin the 4G so its all custom, 60-1 .82 a/r on the turbine. EU already in my posession, and just finished my PNP harness, gotta double check my wiring and test it out on the car. then wire in the harness and time for some data loggin
