Intercooler/intake temp gauge - anyone have it?
I use the seperate IAT sensor (not the one in the MAF) on the Haltech. Watch the monitor as you spray test meth its awesome stuff. LEss than $20 for that sensor, I LOL'd @ the price of that unit....
This is just not a IAT monitor, this unit displays the temperature before and after the intercooler, and also displays the difference between the two so you may know how effective your intercooler and or other cooling source is on the fly.
-George
-George
-George
-George
love this gauge.... aircraft quality.
-George
-George
Not to knock on the expensive but sweet IAT gauge parade - but does anyone know of a cheaper alternative for an independent sensor/gauge setup? I don't need a before and after reading, would like to just install a sensor before the throttle body and have a small digital display in the cabin.
Originally Posted by XKR
You can with one of these...If the probe is after the meth spray you will see the reduction in temps. Just do one run without meth and another with meth.
Will the sensor survive meth over time?
http://www.frozenboost.com/product_i...roducts_id=800
Remember...this thing comes with 2 probes.....you can place it where ever you want.....Before intercooler...after intercooler.....right before meth spray system and right after.
BTW....I have set up a test for meth just to see what it does to stainless steel,aluminum and regular metal. All three have been sitting in a close container half full for over a month now. The regular metal ( house hold pipe) is showing some change...but the SS and Aluminum pipe stays the same.
For reference point....I have also used the same metals and have placed them in the same size containes but this time they are filled with Coca Cola. The Coca Cola is killing the regular matal
I would prefer a smaller display as opposed to a round gauge, but without the need for the before/after twin sensor setup... But all of those I've seen are aircraft gauges priced similarly to the GTM gauge. In fact, GTM's was the cheapest I've seen.
http://hopupracing.com/spinteme.html
Spendy.
If anyone finds a small display similar to the GTM unit, but that uses a single sensor and is affordable, please post it up.
Spendy.
Originally Posted by SpoilsofWar
Remember...you get what you pay for
Spendy.
Spendy.
I paid a little over $400 for mine in '98
I would be willing to bet that the sensor construction is virtually identical regardless of who makes the actual gauge. Hell, I wouldn't be suprised if the sensor itself was manufactured by the same company.
And Nordskog gauges are not exactly junk. But I got it, I know some of you think if it doesnt cost an arm and a leg it can't be a good product.
And I am willing to bet you also that they are not made by the same company !!
With this aircraft gauge you can also set it to display "Difference" which will show you how much the Meth has dropped the temp. So you have Before, After and Diff temps displayed .
You made a good find. You posted a gauge that most would find to be a great price and would rather buy than that one GTM has listed.....but there are those of us ( like me )that want to be dumb and pay alot for a good product.
My guess is it will. I have the exact one GTM is selling....( BTW I paid way more for mine back in 1998......so this is a good price)....My probes are Stainless....so Meth will not be a problem. Because this has held up to over 10years of abuse and still works....I say its an A+ system.
I have a Nordskog gauge for my LC-1, and unfortunately the gauge can't be modified into a rectangle gauge because the PCB is round inside.
how far did you mount the sensor after the meth? I think I only have 7-8 inches left after the Meth nozzle and the Throttle body. It is an interesting product and I can always mount one before the FMIC and use my MAF to measure the IAT after the FMIC and use the other sensor after the Meth...
I have 12" from nozzle to throttle body....but in your case I would put it as far away from the nozzle as possible to get the best reading. That way you would get the exact temp going into the plenum.
Originally Posted by reptile718
? would this device work for water to air IC's as well? If so I want it!
