What does this code mean?
Old Mar 24, 2010 | 06:00 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by nomyth46
go buy one from nissan and see what comes with it...........i've bought 2
I am on my third throttle body and i never got the gas pedal assembly either....i guess i got ripped of too?
Old Mar 25, 2010 | 08:00 AM
Rafa's Avatar
Rafa
I had this problem in my Z for about 6 months and i went crazy with this code until JAPTRIX found the problem, apparently the sensor in the "GAS PEDAL ASSEMBLY" was sending bad codes to the "UTEC" so i had to change both parts and problem solved, i never had any problems again with either one....
Old Mar 25, 2010 | 10:01 AM
QuadCam's Avatar
QuadCam
this sounds to me like another UTEC related issue. It seems like everyone, including me, who has had this throttle issue has also had a UTEC in the loop!
Old Mar 25, 2010 | 01:08 PM
psychoballistic's Avatar
psychoballistic
Yea i'm thinking the same thing rafa and quad are.
OP, sounds like your in the same boat as many of us with the Utec's, they all go into limp mode right when you need them not to.
I disconnected my utec, swapped to stock injectors, left just my stock ecu, and disconnected the charge pipe and put a filter on, and what ya think happened, no more limp mode. So either it's A) the turbo system (doubtful) or B) the Utec causing the issue (most likely).
Sounds like the Utec is a failing system for our cars unless TurboXS can fix this ridiculous issue.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
