vortech Intercooler mounts
Old Aug 14, 2008 | 04:50 PM
turtle1678's Avatar
turtle1678
Default vortech Intercooler mounts
does anyone have a set of the vortech intercooler mounts that it sits on?
Old Aug 14, 2008 | 06:09 PM
str8dum1's Avatar
str8dum1
you only use those to hold the cooler up when you are attaching the pipes. they are not used after everything is connected. weight is supported by the piping and that small side mount connector.
i'd send you mine but i've since cut them up for other projects. you dont need them
Old Aug 14, 2008 | 06:21 PM
booger's Avatar
booger
My shop made some 4 or 5 inch strips with a hole on each end . Used thoughs as supports . Easy fix
Old Aug 14, 2008 | 07:03 PM
clifftrail's Avatar
clifftrail
Just go to the hardware store and by two L-brackets. Same thing.
Old Aug 15, 2008 | 09:18 AM
eez's Avatar
eez
I had to keep mine on...otherwise the damn thing would shift. It's too heavy for one mount on the side IMHO
Old Aug 15, 2008 | 12:07 PM
JET MECH's Avatar
JET MECH
i kept them installed for added support. i installed 3M double sided tape between the cooler and the brackets as a anti chaffe barrier and it also keeps the cooler from shifting.
Old Aug 15, 2008 | 07:15 PM
str8dum1's Avatar
str8dum1
hmm, strange. my cooler is rock solid with no supports. I guess you guys just skipped bolting the undertray in those 2 spots?
Old Aug 15, 2008 | 08:29 PM
eez's Avatar
eez
yep
Old Aug 15, 2008 | 08:58 PM
JET MECH's Avatar
JET MECH
i do not run my under tray, that has been long gone for a while!!!!
350Z_Al
Oct 29, 2020 07:44 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
