Need help APEXI boost controller
Old Aug 22, 2008 | 04:31 AM
Mike_G's Avatar
Mike_G
Default Need help APEXI boost controller
Anybody have a wiring diagram ? I have checked their website. They show it for the 300 but not the 350. Is it the same on the 350s harness?
Thanks
Mike
Old Aug 22, 2008 | 11:45 AM
Mike_G's Avatar
Mike_G
Anybody ?
Old Aug 24, 2008 | 07:42 PM
pmohr's Avatar
pmohr
Originally Posted by Mike_G
Anybody ?
Between the following two images, you should be good (first, AVC-R harness description):
http://boredmder.com/pics/pinouts/2003-2006%20350z.png
The only thing I don't have listed on there is speed, but AFAIK there isn't a speed output from the ECU.
Red is ignition power, black is ground. CKPS POS is your crank sensor (not that it's relevant here). For a straight tach signal, you'll need some sort of tach adapter (unless the AVC-R can use an ignition/injector signal, which it appears it can).
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
