procharger hp gain
Old Aug 3, 2003 | 01:30 PM
ccfbnj86's Avatar
ccfbnj86
Default procharger hp gain
about how much HP does the procharger give the 350Z. is it better than getting a turbocharger? thanks in advance
Old Aug 3, 2003 | 01:49 PM
toykilla's Avatar
toykilla
do a little searching.. there is much debate on which is better for this car
Old Aug 3, 2003 | 02:09 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The Procharger will get the car to approximately 370 Rear Wheel HP compared to the roughly 240 Rear Wheel HP it has stock.
As for which is better TT or SC, you'll have to search and read and make your own conclusions.
Old Aug 3, 2003 | 02:27 PM
ccfbnj86's Avatar
ccfbnj86
also is it possible to put two prochargers in the car
Old Aug 3, 2003 | 02:35 PM
zoasis's Avatar
zoasis
sure, one will have to be in the trunk though. :-)
Old Aug 3, 2003 | 02:39 PM
ccfbnj86's Avatar
ccfbnj86
u can put twin turbo though right. adn that would give it a boost of like 150 hp right
Old Aug 3, 2003 | 02:49 PM
little_rod's Avatar
little_rod
LOL, I have searched, and I have made my own conclusions. Any FI is great. The procharger is good, and I like the results. But you do have to know the difference in the turbo and SC. The SC will have more immediate kick, meaning you will get a 0.5 sec "jerk" that feels good to most people cause it is like ol' muscle cars. The turbo will not have that immediate kick, but they will make more power throughout the rev range. The turbo can be at max boost at 3000 rpm, while the SC will be at half that. So the turbo will make more power at the same boost rating.
The SC will probably be less expensive, will make immediate power, and may come with a warranty. The turbo will only run when you need it, can give you more HP potential, and could be at max boost throughout the rpm range. It is all what you want.
Old Aug 3, 2003 | 02:59 PM
KhanMan's Avatar
KhanMan
SO then its not possible to have to pop chargers
Old Aug 3, 2003 | 03:05 PM
toykilla's Avatar
toykilla
there are some people with serious issues browsing this board
Old Aug 3, 2003 | 03:26 PM
yobri's Avatar
yobri
This thread has more humor than information.... LOL
Old Aug 3, 2003 | 04:14 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Come on guys be nice to the Newbs!
You are confusing the terms.
A Procharger is a brand name of a Super Charger made by a company called ATI.
A POP charger is an aftermarket intake that simply alters the way the car gets its air into the engine. It is NOT a form of forced induction. Oh, and BTW, you can't use two of them at a time.
Pop Charger:
Old Aug 3, 2003 | 04:15 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Procharger:
Old Aug 3, 2003 | 04:16 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
More of the Procharger Kit:
Old Aug 3, 2003 | 04:17 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Now do you see why the second one would have to go "in the trunk"???
Old Aug 3, 2003 | 04:21 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Again, you are confusing terms.
"Boost" is the increase in pressure in psi (pounds per square inch) that is "forced" into the engine in FORCED induction (FI). It isn't measured in HP.
More boost into the engine means it gets more air. More air means it puts out more POWER. It is the engine's POWER that is measured in HP. The amount of HP gained with a turbo (single or twin) depends on A LOT of other things, but in general, the more BOOST (psi) the more HP gained.
***What the h3ll am I explaining this stuff for?? This doesn't have anything to do with Zaino!!!
Old Aug 3, 2003 | 04:25 PM
Buub's Avatar
Buub
Bonz, you could start a "Zaino your ProCharger" movement!
Old Aug 3, 2003 | 05:00 PM
little_rod's Avatar
little_rod
Yeah, he is a newbie, but I think he just misspelled Procharger in his second post. He compared a procharger to a turbo. Then he asked about two prochargers in one car. Then, two turbos in one car. After that, he says, "give it (the car) a boost (another way of saying make it go faster) of 150 HP right".
It is common to have two turbos, but not two SCs. Since SCs run off the crank, if you even tried it, good luck in finding a belt for that setup.
Least that is my take, lol. Don't think (hope) he wasn't talking about two popchargers.....
Old Aug 3, 2003 | 05:19 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
***Note to self. E-mail Sal about new top secret supercharger polymer sealant. Once I apply it to the belts and pulleys, LOOK OUT Ferrari!!***
Old Aug 3, 2003 | 07:34 PM
Chebosto's Avatar
Chebosto
for SC you get max boost near redline, power is linerally gained.
for turbos, typically max boost comes much earlier, but there is an inheirent lag to get there. power is exponentially gained.
.. does the Procharger have a BOV?
Old Aug 3, 2003 | 09:10 PM
little_rod's Avatar
little_rod
Like I said earlier, you get that 0.5 sec kick with the SC cause it is on constantly, then after that, the turbo will rule cause it will put out more boost at lower rpms.
One thing that interests me is that a jerk (kick) is usually not good for mechanical parts. Smooth is always better. What that would mean to me is unknown for an SC. Alot of people just like to stomp on the pedal immediately, but I am usually gentlier on my baby. Seems like the turbo would be gentlier, although it would come on real strong when it comes on.
