Cams and vortech
I am really considering purchasing cams and I was wondering what kinds of gains I should expect, what kind you guys would recommend for a non rev, and what am I looking at to install time wise.
Thanks guys
Thanks guys
realistically, probably 20whp
it'll vary a little with the trade off of low vs high rpm power
the smaller the pulley or stronger the blower you use, the more benefit you'll get from them, but they're not going to perform any miracles
it's pretty much around $2000 to buy cams and get them installed. That was 3 years ago anyway. It might cost more now...
IMO I don't think JDM matters at all. JWT and GTM both make perfectly good cams
do you have to do any other work when you add them, or is there anything other suggested when you change them, and are there any certain specs Im looking for?
about 8 hours. Easily a full day at least for someone who knows exactly what they're doing
turtle, I tried answering your PM, but your inbox is full
not many people have really tried any of the non-mainstream brands or really extreme cams with the vortech. Obviously you do NOT want cams that are too extreme that are meant to make power at 8000 rpms because you will never rev that high with the vortech
IMO I wouldn't go too extreme. Something in the middle of the road is usually what most people are looking for in the end.
I saw someone on here who got JDM which have the same specs as the JWT ones How do you guys feel about those, They are a little cheaper in price, just wondering if anyone knows how they perform
, and 8 hours isnt that bad I thought it was going to be like 14 I have a z shop in the area so that should be easy for them thanks sentry
Its a bit more then 8 hours. Alldata calls for 14.7 hours and that if you leave the factory springs in. Cam install on these motors with the motor in the car isnt fun at all. Have to take both front and rear timing covers off along with the bottom oil pan and loosen the top oil pan. Then you gotta deal with your main seals.
Also...quality...JWT > BC
Originally Posted by booger
Tell me if Im wrong here ........but doesnt boosting a car reduce the spring rate of the springs as boost rises ? Making going to a stiffer spring a must do ?
so I probly wouldnt want to change the springs b/c I am going with the 2.87 pulley and I cant go higher than the redline b/c I will overspin the blower, Is that correct???
