My aem uego is stuck at 14.8 a/f
Old Sep 11, 2008 | 09:02 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Default My aem uego is stuck at 14.8 a/f
Anyone have their Aem uego get stuck like this.It dosent move at all and im suspecting a bad sensor.First startup in the morning it will jump to 15.2 then right back to 14.8 and stays there.
Old Sep 11, 2008 | 09:37 AM
Chris@SP's Avatar
Chris@SP
Sound Performance
You're thinking is right, probably a bad sensor.
Old Sep 11, 2008 | 09:41 AM
superchargedg
Damn Noobs
Thats what i thought so thanks.
Old Sep 11, 2008 | 10:45 AM
UMW350Z's Avatar
UMW350Z
how long did the sensor last you? I wonder how long my Innovate will last...
Old Sep 11, 2008 | 10:47 AM
gothchick's Avatar
gothchick
I've had my aem afr gauge for almost 1 1/2 years. So far so good ~knocks on wood
Old Sep 11, 2008 | 11:07 AM
superchargedg
Damn Noobs
Well this will be #3 as the first one went bad when i blew my cat convertors out.And now this one seems to have cooked.
Old Sep 11, 2008 | 02:28 PM
rcdash's Avatar
rcdash
How are you powering the sensor? The sensor heater needs to be powered ONLY when the car is running. You can shock O2 sensors with cold water vapor if they are hot while car is off and you start it up (e.g. you have it tied to accessory power, turn car off, listen to radio etc, then restart - O2 will be hot and die when cold water vapor in manifold hits it). You can also damage O2 sensors by having them off while engine is running for extended periods.
Old Sep 11, 2008 | 02:58 PM
SC 350Z's Avatar
SC 350Z
^? where do you suggest to hook it up at ?
Old Sep 11, 2008 | 03:23 PM
wannabuy350z's Avatar
wannabuy350z
1.5 - 2 feet after turbo
Old Sep 11, 2008 | 06:13 PM
rcdash's Avatar
rcdash
I use power off of the fuel pump relay for my TXS wideband (the circuit is in the IPDM behind the battery on my G). It's one of the few circuits that has power only when running (except for the initial 1 second prime).
Old Sep 11, 2008 | 06:46 PM
SC 350Z's Avatar
SC 350Z
so the fuel pump relay? ill have to break the old multimeter out
Old Sep 11, 2008 | 07:08 PM
rcdash's Avatar
rcdash
You mean the service manual, right?
Old Sep 11, 2008 | 07:46 PM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
100% definately the sensor.
Old Sep 12, 2008 | 07:10 AM
gothchick's Avatar
gothchick
Haha! That's where I ran mine from also. Except I tapped the circuit by the fuse box and ran an inline fuse instead.:-)
Old Sep 12, 2008 | 07:54 AM
rcdash's Avatar
rcdash
Great minds think alike and all that... Hmmm - now I'm thinking why didn't I do that (instead of going to the relay output). Is the fuse before or after the relay? I actually used a fuse tap on the relay output. It was a pain pulling out that relay too...
EDIT: Or did you mean you tapped the outgoing wire? That would've been easier too. Oh well, either way works.
Old Sep 12, 2008 | 08:06 AM
SC 350Z's Avatar
SC 350Z
so the relay or the fuse?
Old Sep 12, 2008 | 08:20 AM
rcdash's Avatar
rcdash
Any point after the relay will work (since that is what switches power)... I would just tap the wire going back to the fuel pump. Check your car's FSM for the right one. Be sure to add an inline fuse (10 amps should be more than enough).
Old Sep 12, 2008 | 08:39 AM
gothchick's Avatar
gothchick
The factory fuse is before the relay I believe. I gotta check the FSM. I tapped the outgoing wire just after the fuse box, and stuck an inline 10amp fuse between the tap and the AF sending unit.
Old Sep 12, 2008 | 11:04 AM
SC 350Z's Avatar
SC 350Z
if you could let me know cuzz i dont have a FSM i need to get one but if you could tell me what color the wire was?
Old Sep 12, 2008 | 11:07 AM
rcdash's Avatar
rcdash
Wire colors change between model years - and I have an 04.5 G. The manuals are downloadable for free somewhere on this site I think...
