For you built motor heads
Old Sep 22, 2008 | 02:45 PM
350 Rookie's Avatar
350 Rookie
Default For you built motor heads
For those with their 2nd, 3rd, 4th built engines, im just wondering why some of you are on the 2nd and 3rd built motor. What happened to your 1st built motor. Did it blow up or did you rebuild it with stronger internals. And if you did blow up built engine, how many miles before it went and what caused the destruction. Post up.
Old Sep 22, 2008 | 03:12 PM
SpoilsofWar's Avatar
SpoilsofWar
Most of the failures were due to cooling/headgasket/headlift issues. At lot of these guys on multiple engines have been around since the beginning and had to suffer through the VQ growing pains, when what was "the right way to do things" turned out to be anything but.
Old Sep 22, 2008 | 03:35 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I built my motor again because I make bad decisions and love wasting money. Mostly just for fun...I love blowing $hit up what can I say?
Old Sep 22, 2008 | 03:40 PM
marques1's Avatar
marques1
350rookie: Thanks for this thread!! I'm also very interested in this information!
Old Sep 22, 2008 | 03:43 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Old Sep 22, 2008 | 04:33 PM
westpak's Avatar
westpak
SFZCC
sleeve install screw up
Old Sep 22, 2008 | 05:59 PM
r0mey's Avatar
r0mey
Exactly what he said to a T
Old Sep 22, 2008 | 06:20 PM
D350Z10's Avatar
D350Z10
-dont sleeve
Get Forged Performance S1 short block, that is more than enough and it is the most soild motor package out there. Roughly 30%+ are running this setup with no problems. Their motors can take a beating.
Old Sep 22, 2008 | 08:44 PM
Fluid1's Avatar
Fluid1
I'm only on the first built engine, but my research shows that L19 headstuds and a proper headgasket are items of high importance.
Old Sep 23, 2008 | 05:37 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
There is another thread similar to this I would suggest you read through, the built motor guys sticky. Just as spoilsofwar said, most of the rebuilds are due to head gasket issues. There are many reasons these can fail, be it deck prep, tuning, tq procedure, etc. Just having the right parts isn't enough, assembly is key too.
The only motor we have had to rebuild was our own drag motor, and it broke when we intentionally pushed the limits of the BC rods. We broke the rods at 1200+whp, and then rebuilt with stronger ones.
Old Sep 23, 2008 | 07:59 AM
gothchick's Avatar
gothchick
^^^ Dayum! 200whp per rod~ :-)
Old Sep 23, 2008 | 09:25 AM
350 Rookie's Avatar
350 Rookie
I have L19s and the hks headgasket. The studs were torqued to 93 ftlbs
Originally Posted by D350Z10
-dont sleeve
thats what i also have. the s1 block
Cannysage's Avatar
Cannysage
started of with the timing chain guide breaking, tensioner expanded and busted up my camshaft. my rods and pistons never broke. still running stock headgaskets
Old Sep 23, 2008 | 09:31 AM
IslandZavage's Avatar
IslandZavage
What bad decisions was it?
Old Sep 23, 2008 | 05:54 PM
IIQuickSilverII's Avatar
IIQuickSilverII
-dont sleeve if you dont go for 900+whp
Get Forged Performance S1 short block, that is more than enough for 98% of builds and it is the one of the most soild motor package out there. Roughly 30%+ are running this setup with no problems. Their motors can take a beating.
fixed...and werd
Old Sep 24, 2008 | 01:19 AM
wannabuy350z's Avatar
wannabuy350z
good thread,
I im in the process of getting a built motor and upping boost to 15PSI.
http://www.importpartspro.com/st1blon.html
I am considering this short block to minimize down time, but whats your opinion, should i build my stock blow 20K+ miles on it?
what would the machine shop charge for boring, machining and cleaning the block?
would it be less of an error to purchase this short block from Import and just swap the bottom end?
Old Sep 24, 2008 | 08:57 AM
rrmedicx's Avatar
rrmedicx
Hal,
Every broken motor tells a story of what potentially failed. From the looks of the motor in your above post, it would seem that one end of the motor fell apart while the opposite end held up. What in your opinion "Could" be the culprit?
Do you think there is a potential that one end of the motor has better cooling or better oil delivery than the other? Just a thought. Always looking to see if there is any way to improve on what we know...
Thanks for sharing.
Old Sep 24, 2008 | 09:00 AM
350 Rookie's Avatar
350 Rookie
Originally Posted by wannabuy350z
good thread,
I say call forged performnace for this one. I got my block from them and i have 3k miles on mine still running strong, boosting real hard too. and sharif is a great person. willin to help with anything.
Old Sep 24, 2008 | 10:23 AM
wannabuy350z
^ i know he good, but its also 1k more, I will be boosting 15psi on my tiny t25 turbos, max whp will be around 480 and im done
Old Sep 24, 2008 | 05:01 PM
ttuberz's Avatar
ttuberz
ed we all know you are just getting prepared for your built motor to blow again
