world record JWT BB530 350Z ?
Old Oct 3, 2008 | 05:05 PM
SpoilsofWar's Avatar
SpoilsofWar
Originally Posted by superchargedg
Isnt there a song that starts with.......dream....dream....dream.
...Whenever I want (535hp on a JWT 530 kit), all I have to do, is dreeeeeaaaaammmmm......
Old Oct 4, 2008 | 07:21 AM
Mike Wazowski's Avatar
Mike Wazowski
oh my check out their new dynographs....
Originally Posted by mike300zxt
Here is the original print off from the Mustang Dyno. I don't have the boost/AF sheet, but if I recall, the boost peaked briefly at 17PSI before stabalizing at 14.
This graph isn't very pretty as we couldn't stop the car from spinning it's wheels on the dyno. I suspect if it had better traction, the torque peak would be a little lower (~610ft-lbs?) but a lot smooter, and the power would be a bit higher and smoother as well.
The car repeated similar numbers across three runs.
For comparison, here are the dyno runs of this car with the JWT kit the way if comes from Jim Wolf (with their tune), on the same dyno, before the engine was built, and before the JWT kit was modified. Excuse the tracing, the printout didn't scan well without it.
Old Oct 4, 2008 | 07:28 AM
Mike Wazowski
oh and for those that want this awesome world record breaking car, it is for sale in our very own classifieds....
https://my350z.com/forum/cars-sale/3...4-995-cad.html
Old Oct 4, 2008 | 07:34 AM
westpak's Avatar
westpak
SFZCC
well great chart if you are going for peak numbers, that is one wicked peak on torque and then just peters out into the 300's as expected from the tiny turbos, anyone can get peaks like that by adjusting your base boost but the real trick would have been if they had been able to keep the torque up there waste of money to have done the build and stay with the smaller turbos if they wanted big power
Old Oct 4, 2008 | 07:50 AM
Clint@Altered's Avatar
Clint@Altered
Garrett, in some circumstances, severely underrates their turbochargers. Look at all of the Evo guys making mid 6xxwhp with GT3582rs that are rated by Garrett for 600hp. One of the machinists here made 641 at 34psi with a 3582R. We've made (albeit with an HR) well over 500whp/Tq at 11psi with modified versions of the same turbochargers included in the JWT530BB. And at only 7psi, we made 448whp. I don't doubt GT25rs can make that kind of power. Especially if the turbine housings are ported. Coupled with the instant boost response and high torque output 25Rs produce, they make for one hell of a street car.
Old Oct 4, 2008 | 08:19 AM
chris'smax's Avatar
chris'smax
Originally Posted by Clint@Altered
Garrett, in some circumstances, severely underrates their turbochargers. Look at all of the Evo guys making mid 6xxwhp with GT3582rs that are rated by Garrett for 600hp. One of the machinists here made 641 at 34psi with a 3582R. We've made (albeit with an HR) well over 500whp/Tq at 11psi with modified versions of the same turbochargers included in the JWT530BB. And at only 7psi, we made 474whp. I don't doubt GT25rs can make that kind of power. Especially if the turbine housings are ported. Coupled with the instant boost response and high torque output 25Rs produce, they make for one hell of a street car.
Dyno graphs please of 474whp at 7psi?
Old Oct 4, 2008 | 08:22 AM
Clint@Altered
Edit 448 @ 7psi conservative timing. 474 must have been at 8 or so. I'll upload the other chart when I get a chance later. These are great turbos. Literally zero lag. Perfect for stock or built block HRs or DEs. The JWT530BB and 700BB, like mentioned in USN HM 350Z post, are purposefully very restrictive. Keeps boost creep to a minimum. Lol, work a little magic on the piping and turbine and they'll make A LOT more power.
Heres the graph:https://my350z.com/forum/shop-builds...ids-graph.html
Old Oct 4, 2008 | 08:27 AM
Mike Wazowski
Edit 448 @ 7psi. 474 must have been at 8 or so. I'll upload the other chart when I get a chance later.
These are great turbos. Literally zero lag. Perfect for stock block HRs or DEs. The JWT, like mentioned in USN HM 350Z post, is purposefully very restrictive. Keeps boost creep to a minimum. Lol, work a little magic on the piping and turbine and they'll make A LOT more power.
why wont you say what size turbo's you have in that kit? "Top Secret" is not an answer. They are obviously bigger than GT 25XXR's
Old Oct 4, 2008 | 08:31 AM
chris'smax's Avatar
chris'smax
This was on a dynojet? I am not trying to bust your *****, just curious because those are very good #'s
Mike Wazowski
by the way, can you possibly explain why his TQ and HP are crossing at 3900 RPM's?
Old Oct 4, 2008 | 09:57 AM
Clint@Altered
No problem. Yep on a dyno Jet.
They are GT2554Rs with ported Turbine housings. Remember, this is an HR. DEs make 400whp with the standard 530BB it relatively easy. HRs breathe a lot more. Plus the JWT Kits, like I mentioned before, use a restrictive piping system on the DEs. Switch to dual intakes and I'm sure the 530BB will make much more power on the DEs. Turn it up to 18psi, and 500++ hp/tq is attainable.
Ideally, the 2854R would be best turbocharger for a zero lag type street kit. Used for turbo applications on Harley's and such. Its a 25R compressor mated to a 28R turbine wheel with a better turbine housing. But they are usually an impractical option because they are practically unattainable (or at least, were over the last year). TIAL's been waiting for them forever. I want to get my hands on some to test against the 2554Rs.
-Clint
Old Oct 4, 2008 | 10:07 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
simple, cause the axis tq is being measured on has a higher number then the comparable hp axis
look at 5250, tq is just under 530 on the left axis and hp is just under 530 in the right axis.
ugly graphs none the less.
Old Oct 4, 2008 | 11:30 AM
SmallTuner's Avatar
SmallTuner
is this is a 350z dyno graph !!!! its still not tuned right ?
Old Oct 4, 2008 | 11:31 AM
Mike Wazowski
supposedly it is from a 350z.
It is a DE not an HR
Old Oct 4, 2008 | 02:41 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is one of the worst theads ever. What is up with that dyno chart?
I like the one that was made on Excel much better.
Old Oct 4, 2008 | 02:58 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
tuning a built motor on 530bb kit this week. no cams though...
i will see what they will do on 15 psi or so.
nice graph though!!
Old Oct 4, 2008 | 03:43 PM
nomyth46's Avatar
nomyth46
just cause i curious what kind of spark plug gaps are yall running?...........i think mine are at .037
Old Oct 4, 2008 | 06:18 PM
  #38
thawk408's Avatar
thawk408
Old Oct 4, 2008 | 07:28 PM
  #39
SpoilsofWar
Old Oct 4, 2008 | 08:04 PM
  #40
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by thawk408
